PN - 78850-AM80A
that is the updated part. I'd say they fixed the issue you found. I show a 9600 Yen purchase price.
take that part to nissan and get a price.
I lost where I found it in FAST :sick:
OOOH WAAAAAAH.... :huh:
That last picture of the small electric motor, is that the bit seized?
It looks very similar to the R33 Fold in Mirror Motor, with a different gear wheel and I had one of those seized that was 'prised' apart, cleaned up with scotchbrite and crc and re-assembled.
Still works a treat... but wouldn't not turn at all initially.
Check you have voltage to the terminals first.
Hi Stepen.....thanx for your suggestion, but the issue is not one of 'seizure', or friction of any sort.
I should've posted the pics of the motor's exploded view......
I have infact pulled apart the motor (going back to a job I had some 25 years ago..LOL!)....and found the commutator terminals (from the coils) were damaged...
Also found the terminals to the brushes were OC.....Multimeter had confirmed open circuit prior to dissasembly, via power inputs.......blah blah blah.... :huh:
So yeah....I'd love to get just the motor for it....it's looks like a very standard hobby motor, a little larger than normal, but certainly nothing special..(it does have a 'keyed output shaft for the 'helix' type drive')......the ceramic capacitor in there probably only serves as a 'spark/noise reducing' component....whatever....
I have a couple of choices now....
Go to Nissan, down the road......or go to one of the few remaining 'real' tronic houses....Jaycar...(seems that Dick Smith sells white goods now!..grrrrrrrrr!)
I don't mind modding stuff like this...we'll see what happens.
Cool, good work...
Wasn't sure that you had gone that far with motor and yes they do look like something common.
Although, when I started to look for a motor for the R33 Mirror, I couldn't find anything similar. I am fairly sure I tried Jaycar too.
Good Luck
Yeh Dick Smiths, what an excellent shop!
Always been quite expensive and now they have really lost the plot.
There's a lack of real Customer Service with Kids that have no real knowledge too, although Jaycar can be a bit like that and sometimes they can not help in an understandable language either.
yep...I hear ya Stephen.....I miss the times when I'd go to Radio Parts to by my Valves for my guitar amps and old radios (I'm not that old really), go through the STACKS of buckets and trays finding the shit that would really make something dreamy turn into reality, or make it work again...(or just plain let the smoke out of the box..which was fun too!) and that excited feeling I got just strolling through the reems of resistors and caps (on magazine tape), 555 timers, 749 op-amps...the smells, the quality staff that actually taught you something....the project kits..(everything from the electronic 'rolling dice' to the 'cricket insect'..amps, alarms, flip-flop/logic circuits...etc)....the groovy dyi mags......ohhhhhhhhhhhhh.......was it just me?
ok..cool....reality check light....all ok.
I agree, used to really enjoy getting to those sort of shops and making a project, even if I didn't have one.
Always came out more intelligent, however these days... sad but true Customer Service is not what it used to be.
I blame people that don't care and just want the cheapest and nastiest product which seems to go hand in hand.
Hi......(grrrrrrrrr) :P
Anyone got a sparey?
Anyone know where I may be able to find one local?..(hahahaha).
Cheers. :P
Details of car as per below.
REVISED WITH SUCCEESS!!!
I managed to track down a nice little comparible DC motor, albeit rated at 24 volts, but still could easily pull the skin off the custard.
I took it out of a robot arm servo ..(I asked him first before disconnecting it, he said that he'll live)..
I had to grind the end of the motor's shaft, to 'key it, so as to allow fitment into the 'helix' drive gear.
I cut back the brass contacts, and soldered the wires (with a ceramic cap across the input) to what was left of the contacts.
Look, I'll show you my pics......but I'm very happy so far.....I'll install it tonite......along with a piece of string attached to the rear rail, just incase she jams up, and I can't be farrrked taking the trims back out to get to this little horror!
All gears freshly greased....just hope I put pos and neg the right way 'round!!!...ooooops!
That's the old (larger motor) pictured aswell.....the device 'aligns' itself quite well!...(you can have a fair amount of play within the helix and key drive), and she'll still go.
Cheers.
Cheers.
wow! You should put your hand up to be a mini Chris Rogers or next of kin lol.
Good work...let us know if it works.
good work, all the best.
As for the polarity, it will all depend on where the switch is (so to speak) to find out if it will drive the right way. Don't think you want it to drive the wrong way.
you should be able to work out that fairly easily without connecting it first.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
    • Welcome mate. Any pics? Even with a DE I'd be well happy if I had that as a 1st car.
