My self and Erin ( Anahera ) thawt this was quite amuzing today, we both laughed very hard, so we thawt we would show it to you guys!!! Doin' 1 for the team :)
The Yellow ones are mine and the Orange ones are Erins!!
Hahaha
Kels & Erin
  • Replies 50
Posted Images
Well obviously you dont have a sense of humour bubba, so why post negative replies when they are'nt wanted.
Need a tissue?
Section 1
General Rules:
(b) Please refrain from posting meaningless threads, one word (or short) non-sense posts. This includes the Introduction section.
Bubba, while posting the rule to prove your point is fair, its the wasteland man! Thats where this sort of thing should be. I dont see the point to it either, but hey, why not....no one is getting hurt. Hug? :happy:
So why are there rules for the Wasteland forum? Isn't the Wasted Thread where all the useless, pointless crap goes?
I've been told off for making stupid threads in here, OH THE HYPOCRACY
P.S. you can have hugs aslong as you didn't bring home a staf infection from hospital.
Edited by bubba
And this warranted a thread because..?
im sure if it was their nipples they had painted orange/yellow and put pics up you would have been the 1st one in here.
the orange ones are a clear winnah!
now...get back on your treadmill...lol
Edited by DiRTgarage
    • That is way more science than even I would use. I just eyeball it, not even accounting for the non-verticality of the tape measure when held on the lip and the centre at the same time. +/- 2mm is good enough for the girls I go out with.
    • So, before putting them in I need to understand the stock ride height. This is how I measured it: First, check the diameter of the wheel's centre cap, it was 52mm. Then put a piece of masking tape approximately across the centre and measure 27mm (half) from at least 3 sides to get a reasonable idea of the centre of the wheel cap. Mark that with a horizontal line as one measuring point. Then, directly above the wheel on the guard, put another piece of masking tape in approximately the centre. Use a string line to find out the point on the guard above the centre of the wheel cap and mark that. Then it is simple, just a tape measure to check the distance from centre of the wheel to the centre of the guard. Final results where  LF: 381mm RF: 379mm LR: 401mm RR: 400mm Pretty even considering they are 120,000klm old factory springs, lets call that 380 front and 400 rear.
    • So....knowing that I have a problem with power steering temps on track and another Wakefield day booked in next Friday, I've done the obvious thing They are very reasonably priced at $1650, considering they are a big monotube shock, double height adjustable (don't have to change pre-load to change ride height), one way adjustable damping and standard sized and customisable springs if you want something other than what comes with them. They come with 9kg/mm front and 4.5kg/mm front and I went with that as a starting point because I'll add adjustable sway bars too https://justjap.com/products/bc-racing-coilover-kit-ds-ds-infiniti-q50-v37-14-current#description Unfortunately they didn't come with rear strut tops so I've re-used the factory ones which was a bit of a pain. Also, the adjuster for the rear shock will be an absolute nightmare to get at, and while there are extensions in the kit I can't see any way you can actually attach or use them
    • I also had 2 bulbs blow at once, years ago in the stagea. made for a fun drive home. The issue was the voltage regulator had failed in the alternator and it was giving 15+ volts. Really, I was lucky all that was fried were the headlight bulbs. So, I'd suggest you check the voltage across your battery terminals with the car running and warmed up. Yes, you will need a multimeter to do so, sorry.
    • Good work to think to check that, and thanks for coming back to post up the outcome.
