  • Replies 68
would you have the round thin plate with a wire ribbon that sits behind the steering wheel that plugs into the airbag computer is about 2 or 3 mil thick and about 100 mil across if you have how much with postage to tassie pm me or txt call to 0408802254 thanks
I still have the clockspring if thats what youre talking about? $50 posted, PM me if interested
hey mate my post count isnt high enough to pm you but would you do everything in the front cut section
( S2 front bar - paint has flaked/chipped off in some places, needs respray. includes foglights - $350 ono
Front guards - $100 each
S2 headlights - $500 firm pair
S2 bonnet - $250
A/c condenser - $150
Radiator & shroud - $100
Front reo bar (has been cut for FMIC) - $120
Radiator support/ nose cut - $150 )
All of that could you do any cheaper if i took the whole lot in one hit?
I want the front bar, front bar reo and beaver if you have. I can come up to Sydney next weekend and pick up.
Howdy. I've got a S2 R33 GTs-t here in sydney for wrecking. It's had a hit up the back, so the tail lights, rear bumper, and bootlid are gone.. rest of the car is up for grabs though. If youre after anything send me a PM or reply here! Pics at the bottom of this post
It's a '97 S2 R33 Gts-t with approx 146000 ks, Silver/KR4 in colour.
BBS Impul wheels + Falken tyres - $1000 ono
17x8 and 17x9. Rear tyres are on the tread markers, fronts have about 40%. Unsure of offset as its not written anywhere on the wheel, but they fit R33s perfectly. great condition, just a few small gutter marks
5sp Manual gearbox. Shifts well, no crunching. Includes slave cyl, crossmember, shifter and tailshaft - $1500 ono
Can sell as a manual conversion kit if anyones keen
Front end stuff:
S2 grille -SOLD
S2 bonnet - $250
Engine bay stuff:
S2 Rb25 turbo with actuator, good cond, minimal shaft play. Didn't blow any smoke - $250
Impul Hi power control unit remapped ECU - $200
S2 Rb25det engine loom - $150
S2 Rb25det coilpacks - $100
S2 AFM (pink sticker)- $90
R33 aircon compressor pump - $100
R33 power steering pump - $100
R33 alternator - $80
Engine Mounts - $80
Fuse box lid - $20
Washer bottle - $20
Radiator overflow bottle - $20
Charcoal canister - $30
Stock airbox & snorkel + filter - $75
Stock SMIC piping - $50
Stock sidemount intercooler - $40
S2 ABS pump - $100
Bm-44 ABS brake master cylinder - $80
Exterior & suspension/brakes:
Side mirrors - $50 each
Rear SKYLINE garnish (silver) - $40
S2 spoiler minus brake light - $50
Stock suspension with lowered king springs - $250
Front lower control arms - $70 each
Front upper control arms - $40 each
Front hubs - $80 ea
Rear lower control arms - $50 each
Rear 5 stud hubs - $160 pair
Handbrake assembly & cables - $160 pair
Manaual (4.11) ABS diff - $250
Driveshafts $50 pair
Rear upper arms - $50
Front calipers - 250
front rotors - $50
rear calipers - $150 pair
Rear rotors - $50
Interior stuff:
Boot interior, sides, floor, carpet etc - $100
Drivers door window switch - $75
Drivers window switch surround - $40
Drivers door motor/regulator - $80
Passenger door motor - $50
Door trims - $50 each
Instrument cluster with 300km Impul speedo. Unfortunately odometer has stopped (everything else works though) - $150
Dash surround (with clock, hazard switch etc) - $80
Gear stick surround - $50
Ashtray - $25
Glovebox - $40
Steering column surround plastics - $30
S2 dash pad (with passenger airbag & panel) - $350
S2 Steering wheel with airbag - $250
Centre console - $50
Front seats (drivers side has a tear in the usual spot) - $100
Rear seats, good condition - $50
Seatbelts, full set - $80 (will seperate)
Ignition barrel + door barrels + key - $100
If you're chasing any little random bits that arent listed, shoot me a PM. Cheers
post-35556-1233651201_thumb.jpg post-35556-1233651214_thumb.jpg post-35556-1233651188_thumb.jpg post-35556-1233651118_thumb.jpg
SORRY GUYS THIS CAR IS LOONG GONE, STOP BUMPING!
    • Long time no random post about shit. So I went down this deep deep rabbit hole of battery storage for the home, ended up locking in a 41.9kWh Fox ESS EQ4800 with 9 units stacked. Battery uses Lithium Iron Phosphate, similar to what you find in those deep cycle boat/caravan batteries. And yes, why did I go with a cheapie brand and not like Synergy? simply because I don't plan to stay at this house for more than another 3~5 years.  The entire install, DC coupling (removal of existing invertor, connecting the current 6.6kW array direct to the battery invertor), new 8kW invertor is $6K all up (after all the rebates etc.). Going with this lot: https://www.aussiesolarbatteries.com.au/ It did seem a bit too good to be true, however seems like the Whirlpool community has vetted it and when it comes to this kind of stuff, they seem to be all over it: https://forums.whirlpool.net.au/thread/9pxj8482?p=38   I've requested for the battery to be installed outside, next to my meter board and not inside - rather have it combust and ignite outside lol.
    • In Vic it would be a defect regardless of whether or not you cut a hole in the sheetmetal for the return pipe. The rules in Vic are shitful, and are generally interpreted as you can "make 2 mods to the intake system". Putting an FFP and an FMI onto it will almost certainly be seen as some huge number of intake mods. You really need to speak to an engineer before doing this stuff in VIC.
    • planning a r34 rb25 de+t with some other work, rather just have it done in a shop due to space limitations any recommendations? I have most the parts already I seen online Moore Performance and DR Drift any advice appreciated thanks
    • I’ve read the previous posts so just looking for latest information on how people have dealt with front facing plenum is it a defect etc or didn’t pass roadworthy or was it not noticed? Have a r34 and deciding if I should make a hole on the driver side or not.  I know some people have said blitz return flow but I might get rid of the stock intake down the line for a plenum so I rather set up for that now plus I already have a standard Intercooler. Car is mainly stock  Thanks.
    • Actually, if having and keeping the stock ECU is the plan, the correct answer is to put Nistune into the ECU and improve the situation, not just look at it.
