hey all,
just bought an r33 gts-t, all good.
the turbo timer however, is very eager, it likes to count down and cut the ignition whenever it feels like ie) when im trying to drive.
pretty dangerous.
it's a blitz japanese writing something-or-rather, can i disable it simply by unplugging the loom that goes into the back of it, or do i need to get down and dirty with a soldering iron?
https://www.sau.com.au/forums/topic/255425-disabling-turbo-timer/
It'd be easier for you to get down and dirty with soldering iron, however, it might be best to get mechanic/auto electrician if you're not 'electricial savvy' when I removed mine I got my mate to do it for me and it's sweet.
The problem you're describing, it's pretty dangerous - most likely faulty unit or dodgy wiring.
I don't see the point in turbo timer, hence the removal of the turbo timer on my 33, just cool down for couple of minutes before turning they key off, easy as.
Cheers
  • 1 year later...
Just a quick question - going thru the pits early next week, is it possible to just CUT the wires going to the turbo timer unit itself? I wouldnt think so as it would f**k with the ignition system/relays n all that jazz...would the car just stay turned on or wouldnt start? Im fairly handy with a soldering iron so i can solder the unit back on no dramas...any help?
Just unplug it and see if the car will start.
If it does start, then you've fixed it without issues. If it doesn't, then you know you can't just unplug it....is it that hard to work that out? (@repliers, not OP so much :blink:)
My first skyrine had a HKS (I think) timer....had to remove it (see: unplug loom and stash in kick panel) for rego....car acts as normal when it was unplugged.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
    • Sorry I meant that we are building the EH for a client.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
