this is my R33, i moved the charcoal cannister to make room for the catch can. certainly there are neater jobs out there but it gets the job done. there is a cold feed from underneath plus it picks up that bit from in front.
all made from 0.6mm aluminium, lined with some sound deadening and made with hand tools in the garage in case it doesn't show.
Edited by wolverine
https://www.sau.com.au/forums/topic/255433-custom-airbox/#findComment-4405896
well im gonna start mocking up a box/sheild outta cardboard and see what i can do, keep us posted on your sheild man,
this is what i'm going to do. start with a piece of cardboard, see how it looks, then cut and fold up a piece of stainless.
https://www.sau.com.au/forums/topic/255433-custom-airbox/#findComment-4405943
Car is sitting in the sun, engine is turned off, fuel in tank heats up, fuel in tank expands, carbon canister absorbs vapours into activated charcoal, engine is started, engine is run & develops high vacuum, 'purge' line is opened to the activated charcoal, fresh air is drawn through canister into the engine, engine burns fumes, fuel tank doesn't burst open making a big mess.
https://www.sau.com.au/forums/topic/255433-custom-airbox/#findComment-4406133
    • This sounds like someone who would have owned an R33 in their past... It's okay, I'm 100% picking up what you're putting down Mark.
    • Just back on what was raised about jacking off the the tow/tie down point on the front of cars. I've used it plenty. I've also watched it on a car where you could see it move the front end of the car. It was like the front end/whole car being tweaked and twisted a bit. I will say, I struggle to find good jacking points on MOST cars. The ones that have good points, I then normally struggle to find a jack tall enough to make the car change height!   One of my go to points for either the jack, or the axel stands though, is either a suspension pickup point, OR a subframe to chassis major bolting point. I actually think its the subframe on my R33 that has a bit of a bend in it, from being jacked in the middle too. However, it could have been one of my many other cars I've had over the years! Or it could also be the from me jacking it up, and the fact the top of the front radiator support isn't there, so it can allow the front of the car to move and bend etc.
    • My apologies. I forgot we were talking about weird beard M series stuff. Had been talking elsewhere with someone about an R33 with similar subject and got confused.
    • Nope, I don't like the look of ND RF, or any ND really, I don't like their faces or arses, why, because of their "modern" lines, the NC, whilst "modernish" has a more rounded shape that I like Well, that's how my overly judgemental eyes see it anyway
    • Should be more than fine, especially the overall fuel pressure would never exceed 3.5bar (assuming that thing never gets more than 0.5bar of boost in stock form). According to the chart, it's 11amps.
