Two hillclimbs at Fairbairn over the next two weekends with the NSW State Championship on 15th Feb, so the best of the best for all categories will be there.
http://www.sdmahillclimb.com/
Well worth a look and its free to get in.
My car is in peices and making me nervous with only a few days to go! I guess GTRkat understands my torment from when she was trying to get her car out for the xmas cruise.
Who is coming this Sunday? Entries close 8pm tonight.
Michele (if car is ready)
Mark (GTR)
Rebecca (GTST)
Chris (R34)
Jeno?
Jo?
Donnan?
James?? (you really should, you'd go well)
GTRkat should be having a crack at this too with all those mods
A drivers view of the track
CAMS licence and membership available on day, download and take your forms with you to save time, but still need to have entry forms in (email ok) and paid (online ok) by 8pm tonight.
  • Replies 61
want to go to this, been meaning to do a climb for a while now...
but im already booked on sunday :)
*Hijack* Hey chris, What did you do with ur 25 turbs? *Unhijack*
Hey Michelle, did you get the engine back together ok?
we really need to get the clubman back in one piece and out there, when is the next meeting?
Hi Greg - Engine and gearbox went in last night, but she's still has a lot to go. Mark working full time and off to Top Gear for the day tomorrow, so stress factor high atm. We will probably put in a late nighter tonight with help from Jeno <-- *big hugs and thanks*
Next meeting (apart from State Round next weekend) is 8th March, then 5th April - so looking forward to seeing the Clubman out there ;)
I'll also make my car more identifiable so you won't get me confused with Reese - seeing how our driving is so similar.
Na we just thought Reece actually knew how to drive occationally, but now we know it was you all along :domokun:
Top gear for me Sunday. With my custom GTR cap thanks to Reece
Don't forget today and pls come say hi if you come out.
Oh and Richard, bring your glasses this time... I still can't believe you couldn't find where I park :D Even you won't believe it when you see and if all else fails, look for the silver F250 with the slide on camper and the looooong white enclosed car trailer.
Time to get some of that sleep. Twas another fantastic day at the track. Rebecca had a pearler of a day starting with times around 80.18 and finished the day with 62.xx - I won my class, fastest lady and was just pipped for FTD by 100th of a second LOL
I encouraged two new starters for this event, both had a ball and said it wont be their last. One in a black R31 and another in an NA Subarua Impreza, they each had their own challenges and the R31 came out on top for this round.
Great to see a few of you come out to cheers us on.
Thank you Jeno for helping Mark get my car together in time and Jo for sharing him with us.
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
