  • Replies 71
i got a mates steering wheel on with just putting it over my boss kit, the horn worked, then it didnt and we are like wtf? now when ignition is on i have a AIR BAG light which i have never seen before in my life.. let alone my series 1 even have air bags :s and now the horn doesnt work at all checked all fuses and everything we're just stumped.. we got a wheel on but now no horn wtf!
https://www.sau.com.au/forums/topic/255886-defected/page/3/#findComment-4416426
can series 1.5 have just a drive air bag and no passenger?
edit : mines a 95 and when i got it came with a s2 wing, s2 floor mats, s1 rear garnish, s1 front bar and lights
Most S1.5 only have a drivers air bag, S2 got driver and passenger, judging by the year and all the S2 i think there is a good chance it is a S1.5, maybe even a S2.
Do you have an igniter on the coil pack cover up the back, S2 dont have one.
https://www.sau.com.au/forums/topic/255886-defected/page/3/#findComment-4416454
Hey,
Pretty sure most S1.5 has only drivers airbag, can't remember when I last see S1.5 with dual airbags, You might need S1.5 airbag steering wheel to pass RWC.
Hope it helps.
*edit* Brett, aka W0rp3D beat me into it.
Edited by Count Grantleyish
https://www.sau.com.au/forums/topic/255886-defected/page/3/#findComment-4416461
hrmm thats weird cos when i bought the car it had the 'metal middle bit' steering wheel on it so i just thought it didnt come with a air bag.. maybe if i try my brothers s2 steering wheel.. he just bought a s2 r33 (white as well -_-)
https://www.sau.com.au/forums/topic/255886-defected/page/3/#findComment-4416483
yeah i spose you can borrow my wheel on the weekend Leigh - if you help me with my clutch :D
https://www.sau.com.au/forums/topic/255886-defected/page/3/#findComment-4417500
if you can fit the s1 steering wheel and the Airbag light is your only problem, you need to find the wires which used to plug into the airbag. Then you just need to buy a resistor from dicksmith or something and just solder it on or plug it into the plug. this should trick the system into thinking that the airbag is still there and should work fine.
sorry i can't help with what the resistance is supposed to be, i'm sure someone on here would have done something like this.
https://www.sau.com.au/forums/topic/255886-defected/page/3/#findComment-4417531
yeah i spose you can borrow my wheel on the weekend Leigh - if you help me with my clutch :thumbsup:
hahahaha. +1
yeah globe is your best bet.. or alternatively you could try getting it cleared with that holden steering wheel :)
https://www.sau.com.au/forums/topic/255886-defected/page/3/#findComment-4417712
heres a couple of pictures, see the plug thing on the yellow circle, it just doesnt fit through the slot of the wheel slot, and even if it did the plugs at the other end of the wire dont plug into each other.
https://www.sau.com.au/forums/topic/255886-defected/page/3/#findComment-4417855
    • Have you done your thinking backwards? 3 bar, 43.5 psi pressure drop being the presumed specification for an injector, means you need 3 bar upstream when they are firing into atmospheric pressure, and more upstream pressure than that when on boost (you add your boost to your rail pressure to maintain 3 bar across the injector) and you need..... less pressure upstream when you have vacuum in the manifold. So, presuming that you're idling at -10 psi, then you only need ~23 psi in the rail. I realise that I did not need to say all of that to you specifically Matt, once you'd realised your mistake. It's mostly there for complete clarity for others.
    • Have you reached out to the guys at Spool Imports? They are a Ross dealer, I can imagine they would have the rings just sitting on the shelf (I could be wrong).
    • There's one for sale at Grand Auto Wreckers in Lonsdale (SA), for .... let's suggest the sum they're asking for will make you cry. You may have to embrace the idea of modifying the rear subframe to accept some other diff. You could probably find a way to wangle a shortnose into there, with a custom rear adapter and some sort of shenanigans to relocate the front mounts. This has probably already been done by others, so there might be some guidance available as to how easy/impossible it is, out there in the googles. But you possibly needn't restrict yourself to Nissan diffs if you're going to contemplate that. There are similarish Toyota diffs, possibly some Euro ones, possibly some Seppo ones.
    • The ball joint taper and arm taper have to match angle and diameter, but just doing the bushes is a much better option.....seems like the industry moved to "it is cheaper to replace the whole arm than take on the labour for changing this bushes", glad the aftermarket supports it
    • Gee she looks a bit rear heavy in that first pic! Sounds like a great project with the kids, but as I guess you know R series stuff is getting hard to find and pre that is pretty much impossible these days
