hub centric spacers are better then normal spacers but still illegal on the street, better off getting correct offset rims for complete peace of mind.
Are they bolt on spacers and how wide are they? if not bolt on and just slip on, you will need longer wheel studs so the wheel nut still has enough thread.(lve seen what happens if they dont)
im thinking of putting on 15mm hubcentric spacers from justjap on my rear wheels too ..bit worried about the safety aspect of it too. I guess my main concern is the nuts coming off ..but that should be easily fixed with thread tape/locktight (or whatever its called) but theres still the chance of the studs on the spacers being shit quality and breaking (unlike the high quality factory ones) as most of them would be coming from china...
10mm is a wierd size, 10mm is more common as a slip on spacer, but for 10mm slip on ull probably need extended studs. 20mm is the minimum id feel comfortable as a bolt on, as the smaller it is the less meat there is to give a strong mechanical connection.
it also comes down to the wheel, anything smaller than 25mm in bolt on will need cavities in the back of the wheel between the stud holes as ur standard studs are 25mm long, so they will protrude out of the spacer.
oh yeah I forgot about the adapter thickness and original studs sticking out .. 25mm would be a bit too extreme for me I think as the wheels would stick out too much. How hard is it to cut 1cm off of the original studs so they can fit with 15mm adapters? would there be enough thread left for them to hold the adapter safely??
i wouldnt reccomend it.
what a PITA .. wish I'd hadn't pussied out when I was buying my wheels and just got wider at the back .. I thought 9.5" would be too wide but it'd be perfect :huh:
What offset did you get for rear? the +29, 8.5" all round? I thought they would be a good choice too with 245/40/18's.
on my old R33 l used bolt on hub centric 10mm spacers they came with special flatter and tapered wheel nuts so they sat flush, l also didnt need to cut any stud off, but my rays rims(18x9 +20, gtr rear guards on gtst) had quite large dished sections where the studs went.
But trust me l never felt safe driving on them it was always playing on my mine. ; will never use them again l just got the right offset this time round.
And yes l would highly recomend using locktight(threadlocker) on the inside wheel nuts.
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
