Help :( R32 Hard Brake Pedal, Can't Find Out What It Causing It.
Heres the story:
Bought an unreg R32 GTS4 that had been sitting for a while. And now it wants to go over the pits and has failed twice for a hard brake pedal. So far this has been done:
Brakes bled
Front & Rear calipers reconditioned
New pads fitted
Master cylinder reconditioned
Rotors skimmed
Brake booster pressure tested
The brakes react to first part of pedal travel but go solid when trying to press hard, ie in a emergency stop. This is why pits said they won't pass it.
NOTE: Car has factory ABS fitted.
So far, can't get rid of the hard pedal. Beginning to suspect while booster has passed pressure test, it is miss-performing. Has anybody got one that they can lend me to test? Or if it comes to it, anyone have a good condition one to sell?
Anybody had this problem before? (Rmb ABS fitted)
0431 985 155 is my dad's phone number (Tony).
(I'm still on Ls)
Sounds like air in the system,
But if you have bled them, it should of corrected the problem.
There is a particular way you bleed the brakes with ABS as well.
Not sure if that is just for GTR though.
Other than that, I am stumped!
Yeah, it's been done by my mechanic who used to do ferraris lambos tractors :thumbsup: (ex-barbagello) etc etc, basically fixes anything, except my line!
It doesn't feel like air cause if just driving normally, they are fine. Its when you brake to a certain point that it becomes rock solid and you really have to press hard for the car to stop. (Don't get me wrong, it stops really well, its just the hard pedal) The guy at the pits said sure, your average joe could stop the car, but he's referring to when say eg a girl is driving and they can't press the pedal, ie making it too dangerous.
I want the car on the road :| This is the only thing stopping it and its starting to annoy the hell out of me. Stupid skylines :P
Edited by Ten Four
Doesn sound like air in the system, that gives the opposite effect. You put your foot an the brake and nothing happens for a while because you're compressing the air.
Sadly, I cant think of what it might be.
Rhys,
Air in the system can in fact cause block peddle mate,
I understanded where you are coming from,
But to discount air from the system completely at this stage, may in fact lead you down the incorrect path.
There is a sequence that you have to bleed the brakes with ABS in a skyline if it is to be done properly.
There is write up for this in the GTR Manual that can be found online.
Once you have cleared the system completely, then can you move onto the next fault finding excercise.
Nav had a very similiar issue with his car.
Cheers
Mike
Thanks for the replies guys.
Flash, it's not much different, both on and off are pretty hard.
Mike, where is this guide? Otherwise the air has been pretty much discounted at this stage. Its acting more like the booster so I'm going to try get one (to a point its fine, after that its just hard). Cause the car still stops really well, its just the firm pedal.
Defective, the lines are not twisted or split cause each was tested. Brake fluid was replaced earlier today.
Ahh 33, I think I may just do that, thanks.
Edited by Ten Four
Have you tried taking it and stopping by a couple of performance workshops to get their opinion on what it could be? They might have come across this issue before and know the solution.
Yeah mate, as a last resort I will probably end up taking it to a performance workshop. I'm sure the problem is something silly. If the brake boosters I've just bought and the disabling the ABS don't fix it, I'll take it to one.
Who idea was it to do the above mentioned repairs ??
Get a Brake specialist to check it out . ( a good one also )
Rhys,
Cheers
Mike
Mmm i know you might be the guy who gave me the warn on this but ima have to say fail on that one aye, as a mechanic i can say that air in system will cause a spongey pedal and lesser response upon application
Its sounding more like booster but also check where the vacuum line connects to the manifold, start it with that line off and make sure its sucking in air, also check that the booster vacuum hose isnt sucking closed under vacuum when you push the pedal
Dsturbed, the car had been sitting for 1.5 years so the above jobs were done as to be expected. However, it didn't change the brakes much.
Takushi, that has been done a few days ago.
Update: it isn't the ABS.....
Edited by Ten Four
Hey might sound odd but can you post up a pic of the brake booster....
i had a brake specialist test my old TX-5 booster and it was fine then i had the same problem..
i found there was a one way valve in the booster due to boost and it was the wrong way around :D so please check you dont have one or it is the right way around.... also you say you tested the line,,, did you actually start the car with a vacume tester on it then rev to boost to see the difference?? and what was the difference??
Hi guys, problem seems to have been solved.
Previously, the master cylinder must have been taken apart as a washer was missing and the piston was bigger than usual (looked like nothing was out of place...). Replaced washer and put a shorter piston and it seems to have solved the problem. In essence, the car still brakes just as well as before, just with a softer pedal now.
Will be visiting the pits tomorrow.. Cheers.
Edited by Ten Four
    • Hi, wondering if the HKS bar and water reservoir still available? Thanks
    • What an awesome idea to fit the facelift Lamborghini Diablo headlights. They are a perfect fit!
    • An update regarding the registration with the DVLA I sent off the paperwork the day after I collected the car from the port, two weeks later it was all returned with a letter explaining they have rejected the application. This was because the cheque was £20 short for the road tax (I used a price list I found online). Nevermind it is what it is, it was sent back to them the following day with a new cheque. Fast forward another 2 weeks or so, I called them for an update to be told it had been rejected. Yesterday (16th September) I received the documents back along with another letter, this time it was because I didn't put an X in one box on the V750 (personalised number plate certificate), which declared that I had the rights to the personalised number plate. Why this wasn't mentioned in the first rejection letter, I don't know, but it could have saved this headache. The documents were sent back today, so fingers crossed third times a charm and it'll FINALLY be registered on the road just in time for the bad weather (woohoo!) To cheer myself up I lowered the front 25mm, was sick of seeing it sit like a monster truck. No idea how much clearance I'll have getting on and off the driveway, I'll worry about that when I can actually drive it
    • You're going to miss not worrying about rust in the strut towers like the Skyline shitboxes out there
    • A few little updates that weren't filmed due to not taking long to do or not interesting enough for their own video. My new K&N Air Filter arrived, I went with an RU-4180 which matched the dimensions of the universal cone filter the car originally had.  The battery had gone flat, while that was charging I tidied up the spaghetti wiring at the bulk head and down the sides of the engine Next job was to swap the stereo The Kenwood harness had the female ISO plugs cut off and the male ISO plugs cut off the adaptor loom and joined with bullet connectors. I ordered in a repair loom through work and re-did it all. New Kenwood unit installed (Android Auto, DAB, Bluetooth, Reverse Camera) The bonnet/hood gas struts have been poor since collecting the car. I couldn't find any suitable replacements locally so took a chance on a pair from AliExpress.  The originals don't use a retaining clip to secure the cup onto the ball fixture, would explain why I struggled for 10-15mins trying to pry off the cups. The ball fixtures unscrew using a 12mm spanner, new ones are the same size. Sadly no photo of them fitted, you're not missing much lol The dished Momo steering wheel got replaced with my Momo Tuner, turns out I ordered counter sunk bolts for the horn trim ring (like they normally are for the steering wheel) instead of allen cap (flat seat)  A terrible photo of a Quaife style gear shift knob I've had stashed in my tool box for many years after purchasing the incorrect thread size (I can see a pattern emerging with ordering incorrect parts...) Also threw in a cup holder and a (empty) Boss Coffee can, because why not
