For sale-
180sx vented carbon fibre bonnet in good condition.
has been clear coated and has black infill in center vent.
has washer jet cut outs and comes with jets.
$500
R32 gtst type m front bumper
has been cut out to fit front mount
condition ok, stone chips but no cracks
$120
R32 gtr front bumper
has been cut to allow more air flow to cooler (not my handy work)
missing lower lip
condition ok, no cracks.
$100
A'pillar gauge holder to suit skyline, r33 i think.
60mm holes
trail fitment welcome to ensure is 33.
$60
All parts located north of adelaide near Gawler
Cheers.
Jarrad.
https://www.sau.com.au/forums/topic/255935-r32-bars-cf-bonnet-gauge-holder-sa/
its very close to 32 which makes me think it might be for 33.
could prob get it fitting better with some heat gun work, wouldn't take much.
welcome to trial fit.
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
