I've gotten hold of this part called a boost cooler. its made by www.snowperformance.net
either way I have no idea how it works, this video says they don't need an intercooler and its meant to run better than an intercooler....
http://video.google.com/videosearch?q=boos...4&ct=title#
Can anyone explain how this works as i have the ecu for it but haven't met any one who knows what it is lol.
It was given to me from a mate who recently moved to USA and recons its what they useing up there now.... :geek:
makes sense, but i dont think it would be very practical for street use as you would have to have 3 seperate fluid seystems fuel, meth and water.
ok for drags though.
two fluid systems water/meth mix and petrol, the way the boostcooler setup works is that its boost activated. it only consumes the water/meth mix while you have say more than 6psi of boost or how ever you choose to set it up.
does it make a differnce?
who installed it? and is there someone here that sells parts for them?
i only have the black box (the expensive part of it)
a) yes, although you need to pay for a re-tune. Then you run the risk of blowing up your motor if the pump fails at high boost, or you run out of meth.
b) you can do a search,
c) as far as I know, parts (nozzles, tubing, pumps, etc) come from dealers in the states - for example, via ebay, you'll see lots of listings.
d) the pump is also expensive.
running out of meth is only an issue if you don't take at least the basic precautionary measure of installing a level switch in the tank so that you know ahead of time via a warning light that it is getting low.
of course but just an example.
could also be a blocked nozzle, a split line, a failed pump or failed controller..
it probably won't happen but a good system will have some failsafe mode.
    • Ok I get you. But isn’t the butterfly intake a headache with the +T?  see this is my plan so far but please advise me into the right direction.  Nistune Ecu, 1000cc Bosch injectors, TD05 or TD06 Kinugawa turbo using stock rb25det exhuast manifold, walbro fuel pump unsure of model I think it’s 450/460, spitfire coils and sparks to suit and a R35 MAF sensor and boost sensor.    I was thinking maybe do a cheap eBay plenum $400-500 or try find a stock det neo intake. I think I’d port match it so it’s getting the full capacity but open to advice please.  Thanks
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
