might chuck this up on calaisturbo.com.au unless anybody has any objections...i'm sure some people would be interested in helping out
yes you should i wanna see some nice vl's .
i'm coming.
instead of a caterer should just have a bbq to raise money or do both and make a flyer who cares if there is not enough food cos the more people the more money raised .
  • Replies 71
cos i know you guys are worried about not having enough food for everyone but the more people the better
i want to see heaps of cars not just 100 like the rest of the ones i'v been on
Edited by wannaslide
too easy i will keep you posted on numbers.. and if anyone else would like to put there hand up to meet at shell nudgee just mention that in your post so we know how roughly how many.
and going by google maps it will take roughly an hour to get to yamanto from nudgee, so to make the 8-30am departure from yamanto i think its best we meet at 6-45 and depart at 7am giving us plenty of time to get to yamanto meet.
Keen, be there in my evo if it goes ahead and i dont get stuffed over with work.
Edited by sinistagtst
We can get enough food as long as we have a estimate on how many are coming. It's not catering so much as it is food and drink vans.
ok its just i was reading the post on the skylines qld link and someone wanted to make up flyers and put in autobarn ect and the organiser said to just keep it cyber flyer so you can get an estimate for the caterer but i just think there is alot of people out there with nice cars that dont go on car sites
will be about 10-12 evos there from evo oz if not more
gret stuff mate. could you direct them to the thread to check out the new starting point. local police have directed us here to avoid roadworks. cheers.
Hojak, here's the details for the southside meet up.
Those keen.. details below,
Meet: Sunnybank Pinelands Shopping Centre Carpark (left hand side where nando's is)
Time: 7:30am meet and leave right on 7:45am and no later!!
prize up for grabs from me:
I dont think these are on the shelves yet :P
3 of them are up for grabs on sunday... 2 plain ones and one that will control an Ipod.
find me on sunday for info :/
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
