the local spanner can't remove my nuts, either with his sockets or
with the stock tool that came in the trunk .. neither will insert deeply
enough into the hole around the nut to grab more than the first mm of it..
in other words, there isn't enough space around the nut to put the socket over it..
these are lmgt4 and the nuts are black anodized.
What is this? some kind of funky anti-theft system??
is this one of those comes-from-nowhere problems we all get, or is nothing simple?
never mind I found what I (and they) are missing:
a 17mm lug extension adapter..
http://www.courtesyparts.com/nismo-350z-al...cPath=7739&
edit: nope, that isn't the problem. The problem appears to be unique for me..
whomever installed these lmgt4s put back on the original nuts, instead of
rays 17mm nuts, using a magical tool that was so slimline, it fits in the holes :D
now I have to find that tool again before I can remove my wheels!
Edited by moneypit
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
