Hey All
I current have a 97 R33 and have the following mods
Greddy frount Mount
3" cat-Back Exhaust
Turbo smart Dual Stage Boost controller
Aftermarket BOV
POD Filter
Catch Can
front Strut
Rear Strut
Im getting a Vi-Pec replacement ECU installed in a few days and just curious about after the install and tune of what sort of power figures it will make....With current mods im running about 11-12psi.....
How much more power do you think i will get from the ECU upgrade?
https://www.sau.com.au/forums/topic/256409-ecu-upgrade/
To be honest I dont think you will make that much more max power
but it should have a much higher average power and mid range :P
That is where you will notice it on a stock setup like yours vs a stock setup + ECU upgrade and tuned
Hope for around 190kw - 205kw
Although in light fo the fact you have both front and rear struts you might hit 212rwkw! :D
https://www.sau.com.au/forums/topic/256409-ecu-upgrade/#findComment-4418291
Oh I didnt see that! Definitely need a Full exhaust before you get it tuned
Who is tuning / supplying the Vi-pec?
getting it all done and tunes from Mercury Motorsport in Windsor QLD.
Also if i get dump pipe after cECU will i need a retune?
Edited by SCR48
https://www.sau.com.au/forums/topic/256409-ecu-upgrade/#findComment-4419531
well its not really problem its just going to restrict the true potential of what the setup can produce
when my car was fairly stock the addition of a custom made split dump and front pipe really opened it up
the stock dump is pretty restrictive so its just going to limit your power / performance a little
https://www.sau.com.au/forums/topic/256409-ecu-upgrade/#findComment-4419660
No worries man - good luck with the tune - be sure to post back here tonight with the results and what you think of the new ECU
Will do but it will have to be tomorrow as They wanted to keep it overnight to do what they called a "Cold Start" [No idea what that is] in the morning so i should get it around midday or something tomorrow. Hopefully i will get a dyno read out and post her up to... I paid $1735 for the ECU and another $800 for Install and Tune.... is that a decent price?
https://www.sau.com.au/forums/topic/256409-ecu-upgrade/#findComment-4419707
Means they will adjust the tune on the car in the morning when it is completely cold to make sure it starts and idle's properly.
Price seems allright, however you really should have done that dump pipe before the tune as its going to be restricting it something fierce.
My expectations are 175-180rwkw.
Edited by PM-R33
https://www.sau.com.au/forums/topic/256409-ecu-upgrade/#findComment-4419715
Its a little on the expensive side - Mark at Godzilla does it for $2200 fitted and tuned
But if you are happy with Murcury and their Tuning go for it - I have never had anything to do with Mercury so I cant really comment
If I was to get a Vipec I would probably go to Godzilla
I am tossing up between a Vipec and a Haltech E11V2 at the moment
https://www.sau.com.au/forums/topic/256409-ecu-upgrade/#findComment-4419810
5 kw atw seems pritty crap to me my friend got hes subaru impreza wrx sti ecu remaped for like $2,000 and he gained 42kw atw and all he had done was a after market exhaust and a frount mount intercooler because the reseason u can get so much is because the factory ecu dose not no u have all the moderfications done to the car and it pulles back the power because it thinks the engine is going to get damaged so after remapping the saftey setting they beefed up the fuel going to the engine so they could turn up the boost and the guys said it was not a one off thing most car that they do gain 35-45 kw from it so a 5 kw gain seems pritty perfetic but i dont no it might just be the one u got
https://www.sau.com.au/forums/topic/256409-ecu-upgrade/#findComment-4434027
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
