Has anyone on here bought this kit of them? I was quoted $485 + $170 delivery to Adelaide. What's the quality like? My main concern is that if it's too low the Mrs will crack it quick enough. Thoughts?
http://www.blitsbodykits.com.au/nissan.htm
Edited by webng
https://www.sau.com.au/forums/topic/256470-blits-bodykits/
  • Replies 51
Posted Images
nick, it's a low bar so it's going to cop abuse...
i'e got a genuine dolphin bar so can't comment on fitment/quality of the copies but speak to jamie as he had one of the blitz kits in his possession
ps i still want the dayz bar :down:
https://www.sau.com.au/forums/topic/256470-blits-bodykits/#findComment-4418967
Hi
I bout that kit from blitz a while ago and with a guard to centre of wheel measurement of 350mm you will only have about 100mm ground clearance. What I did was to cut it and take 25mm out of the middle giving me a bit more clearance 125mm. There is a fair bit of fitting required in the way of wholes for the grill and so on. post-25786-1234261688_thumb.jpgpost-25786-1234262305_thumb.jpg
I ended up buying two front bars the idea being that if one was badly damaged I could swop them and repair the damaged one at my leisure
Witches hat at 100kmph if I did not have the 3mm aluminum plate attached to the bottom of the front bar it would have been a lot worse
Phil
https://www.sau.com.au/forums/topic/256470-blits-bodykits/#findComment-4419040
feck me that's low... looks like i'll scratch that idea then. Might go the Type M from Viva after all by the looks of things. That looked about 40-50mm lower then the existing Dayz bar.
EDIT: Which do you guys reckon is lower, the Type M or the Dolphin type one?
Edited by webng
https://www.sau.com.au/forums/topic/256470-blits-bodykits/#findComment-4419105
my car is dropped quite a bit though (lol) - if you want, i can measure how far my bar drops down from a specific point and you can ask ruby to do the same since he just fitted one of the viva type m (masa) front bars to his rig ;)
https://www.sau.com.au/forums/topic/256470-blits-bodykits/#findComment-4419197
oh ok.
i like the idea of the metal plate, although i'd rather put it inside the front bar out of sight, but then it has its purpose outside.
been chasing a dolphin kit since i knew they exsited. just never have the funds, got cash now ... but its forr my 100k serivce i just dropped it of this afternoon !!!!
https://www.sau.com.au/forums/topic/256470-blits-bodykits/#findComment-4419214
my guard to centre wheel measures 380mm. Which would give me 130mm according to Stage1. Mike, yeah i realise yours is dumped!
Mike, if you could give me the measurement from point A to point B along with the measurement from wheel arch to centre of wheel and clearance that would be great (like what Stage1 did). I'll get Rube to do the same with his.
thanks
Edited by webng
https://www.sau.com.au/forums/topic/256470-blits-bodykits/#findComment-4419270
Eyebrow height 320mm? Bloody hell... that's low! If my calcs are right, the bar will only be ~40mm lower then the existing one. I can live with that. Thanks mike.
and eyebrow height is ~320mm
Edited by webng
https://www.sau.com.au/forums/topic/256470-blits-bodykits/#findComment-4419446
From what I've seen their fibreglass work is pretty good. Nice, thick, strong and a flat finish. I'm picking mine up today with sideskirts and bonnet to go get painted. Talking to spray painters, there can be huge differences in the finish of the fibreglass from various companies. Even big names put out kits that still require huge mount of effort from the painter to ensure a flat finish because of a poor gel coat. From what I've seen blits' finished products require little prep work. The guy painting mine worked on the V8 Supercar scene for a number of years so he know fibreglass. I'll keep you posted.
Cheers
https://www.sau.com.au/forums/topic/256470-blits-bodykits/#findComment-4419571
Cool, no ADR worries then.
i keep scrolling pass the pic of your stag Mike and DAMN that's low...!
A lady from Blits bodykits emailed me a measurement of 46cm from bottom of headlight to bottom of bar. Choco or Mike, can one of you confirm this, if possible? Do you reckon yours Mike which is an original will be exactly the same dimensions as these copies?
body kits do not need to be adr approved
https://www.sau.com.au/forums/topic/256470-blits-bodykits/#findComment-4421149
    • So either way it is gearbox out and look what is wrong?  I know about the input shaft bearing. Even before swap/new clutch the it sounded exactly like this: So is that inout shaft bearing or the other was installed backwards?  And can some please tell me the part number for that input shaft bearing? The gearbox is small box from R34 N/A and number is FS5W71C. Thank you
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
    • D2 and Ksport are essentially the same thing and basically just generic Taiwanese manufacture. Better than ChinaBay crap, but... not top shelf. Öhlins have got to be some of the best dampers around, so likely to be a good option. It's going to get to the point though where I suggest you buy from Oz. We have at least 2x excellent options here. If I were you though, I'd be talking to KW about doing something for the R33. There's bugger all difference between that and the 32. In GTR land, anyway.
    • KW only offers a set for the R32 GTR. Popular options are D2 racing, Ksport or Öhlins. I have a D2 Racing coilover set, though I don't know for sure which one.
    • Well, the good news is you have more than one very good option for new coilovers in and around your country. Worth the drive over to KW to talk about GTR stuff.
