Has anyone on here bought this kit of them? I was quoted $485 + $170 delivery to Adelaide. What's the quality like? My main concern is that if it's too low the Mrs will crack it quick enough. Thoughts?
http://www.blitsbodykits.com.au/nissan.htm
Edited by webng
https://www.sau.com.au/forums/topic/256470-blits-bodykits/
  • Replies 51
Posted Images
nick, it's a low bar so it's going to cop abuse...
i'e got a genuine dolphin bar so can't comment on fitment/quality of the copies but speak to jamie as he had one of the blitz kits in his possession
ps i still want the dayz bar :down:
https://www.sau.com.au/forums/topic/256470-blits-bodykits/#findComment-4418967
Hi
I bout that kit from blitz a while ago and with a guard to centre of wheel measurement of 350mm you will only have about 100mm ground clearance. What I did was to cut it and take 25mm out of the middle giving me a bit more clearance 125mm. There is a fair bit of fitting required in the way of wholes for the grill and so on. post-25786-1234261688_thumb.jpgpost-25786-1234262305_thumb.jpg
I ended up buying two front bars the idea being that if one was badly damaged I could swop them and repair the damaged one at my leisure
Witches hat at 100kmph if I did not have the 3mm aluminum plate attached to the bottom of the front bar it would have been a lot worse
Phil
https://www.sau.com.au/forums/topic/256470-blits-bodykits/#findComment-4419040
feck me that's low... looks like i'll scratch that idea then. Might go the Type M from Viva after all by the looks of things. That looked about 40-50mm lower then the existing Dayz bar.
EDIT: Which do you guys reckon is lower, the Type M or the Dolphin type one?
Edited by webng
https://www.sau.com.au/forums/topic/256470-blits-bodykits/#findComment-4419105
my car is dropped quite a bit though (lol) - if you want, i can measure how far my bar drops down from a specific point and you can ask ruby to do the same since he just fitted one of the viva type m (masa) front bars to his rig ;)
https://www.sau.com.au/forums/topic/256470-blits-bodykits/#findComment-4419197
oh ok.
i like the idea of the metal plate, although i'd rather put it inside the front bar out of sight, but then it has its purpose outside.
been chasing a dolphin kit since i knew they exsited. just never have the funds, got cash now ... but its forr my 100k serivce i just dropped it of this afternoon !!!!
https://www.sau.com.au/forums/topic/256470-blits-bodykits/#findComment-4419214
my guard to centre wheel measures 380mm. Which would give me 130mm according to Stage1. Mike, yeah i realise yours is dumped!
Mike, if you could give me the measurement from point A to point B along with the measurement from wheel arch to centre of wheel and clearance that would be great (like what Stage1 did). I'll get Rube to do the same with his.
thanks
Edited by webng
https://www.sau.com.au/forums/topic/256470-blits-bodykits/#findComment-4419270
Eyebrow height 320mm? Bloody hell... that's low! If my calcs are right, the bar will only be ~40mm lower then the existing one. I can live with that. Thanks mike.
and eyebrow height is ~320mm
Edited by webng
https://www.sau.com.au/forums/topic/256470-blits-bodykits/#findComment-4419446
From what I've seen their fibreglass work is pretty good. Nice, thick, strong and a flat finish. I'm picking mine up today with sideskirts and bonnet to go get painted. Talking to spray painters, there can be huge differences in the finish of the fibreglass from various companies. Even big names put out kits that still require huge mount of effort from the painter to ensure a flat finish because of a poor gel coat. From what I've seen blits' finished products require little prep work. The guy painting mine worked on the V8 Supercar scene for a number of years so he know fibreglass. I'll keep you posted.
Cheers
https://www.sau.com.au/forums/topic/256470-blits-bodykits/#findComment-4419571
Cool, no ADR worries then.
i keep scrolling pass the pic of your stag Mike and DAMN that's low...!
A lady from Blits bodykits emailed me a measurement of 46cm from bottom of headlight to bottom of bar. Choco or Mike, can one of you confirm this, if possible? Do you reckon yours Mike which is an original will be exactly the same dimensions as these copies?
body kits do not need to be adr approved
https://www.sau.com.au/forums/topic/256470-blits-bodykits/#findComment-4421149
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
