EVENT OPEN
ENTRIES OPEN,
this is drift only event
TIME TABLE
7:30AM GATES OPEN
8:00AM SCRUTINEERING
8:30AM DRIVER SIGN ON
9:00AM DRIVER BRIEFING
9:30AM START TRACK ACTIVITY
11:30AM LUNCH
12:00AM DRIFT SOCCER
12:30PM RESUME TRACK ACTIVITY
4:00PM BIGGEST ENTRY
4:30PM END TRACK ACTIVITY
SPECTATOR
everybody is welcome to spectate at our events entry will be a gold coin ($1or $2) per person
all gate proceeds collected will be donated to a charity
we have an associate membership package available for spectators
costs $40 you get t-shirt, sticker, membership card & a free drink at all our events
you can apply for this on the day.
SCRUTINEERING
your car will need to pass scrutineering
brakes, brake lights, seatbelts/harnesses, windscreen wipers all need to work properly
drivers seat must be secured properly all wheel nuts must be present
you will need a secondary bonnet restraint if you dont have one just bring a short rope & the
scrutineer will assist you installing it
DRIVER
to drive you will need appropriate clothing (non flamable)
your clothes must cover you from neck to wrists to ankles
closed shoes must be worn
and only helmets with the AS1698 sticker affixed can be used
COST
$130 if your a member with driftmob & have a cams license
$150 if your not a member & have a cams license
we can issue you with a cams license on the day
if you want to become a member you can apply on the day
HOW TO PAY
entrants can pay on the day but we recommend prepaying to secure a spot
at this stage we can only accept cash if you want to pay on the day
PREPAY
deposit total amount and bring your reciept with you on the day
no prepayments after thursday 19th
ACCOUNT NAME = DRIFTMOB INC
ACCOUNT NUMBER =259589
BSB =032372
BANK =WESTPAC
just a quick run down for the day,
we are track time orientated this means we will not stop for lunch
the bbq will start at 11:30am finish 12:30pm this will give drivers an hour to get their food
only drivers are entitled to a free feed
BIGGEST ENTRY & DRIFT SOCCERS is not a competitve activity its purpose is to entertain & show the spectators the drivers extreme skills, all skill levels are encouraged to have a go
ANNOUNCEMENT
after our regular admin meeting
DRIFTMOB has decide to honour other drift club memberships!
this means if your a member of any drift club in australia & can produce a valid membership card
or sufficient proof & you want to drive at our events you only pay the discounted members price
providing you apply for an accociate membership which costs $40 per year
you can apply on the day.
https://www.sau.com.au/forums/topic/256484-driftmob-drift-day/
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
