Read those how to get more power threads.
Look at the power results threads to see the gains that have been had with different modifications (remembering that it costs a lot to get power out of an N/A)
The for sale Business Traders section is a good place to get prices from, and a lot of these sponsors give special pricing for SAU members: http://www.skylinesaustralia.com/forums/Sa...aders-f141.html
Also have a look in private sale threads, you might find some good bargains.
For labour, none other than your local exhaust shop/performance workshops/tuners. I'm sure a brief search in the Vic forums will reveal some good tuners in your area, they'll be able to tell you how much what you want is going to cost.
To give you a rough idea though and a starting point (it sounds to me that you want a brief rough estimate of what these things can cost, and where to begin):
2.5" Catback Exhaust ($400-600 for a custom exhaust, depending on whether it's press bent or mandrel bends, the type of tip used etc..)
Hi-Flow Panel air filter such as a K&N Panel...or get a Pod style filter (non-oiled) box it up and run a Cold Air feed for best results...you'll probably find that you NEED to do that anyways in Vic, might be easier just to go with a panel and done. Allow $70-90 for one of those.
Extractors, allow up to a grand for a set of Coby's from NZ, or DKNE extractors from Aus, with HPC Coating and Install and Exhaust gasket.
Hi-Flow Cat <$200 for something suitable for an N/A
After that you then look at something to adjust air/fuel ratios if you want to fine tune it, maybe cam gears to adjust timing, add to that install costs and tuning for maybe a few more KW's. To be honest, with that level of modification the factory ECU after a reset (disconnect ground cable from battery, foot on brake for 5-10seconds, reconnect) will relearn quite well.
After all that it's the bigger stuff like camshafts, port polishing, etc... and then you're talking bigger dollars as not only do you need the parts, there's a lot of labour work involved when working on the engine internally particularly if you look at port and polish, then you WILL need engine management installed and tuned and just engine management and tuning alone can cost $1500+ easy depending on who tunes it and what you use.
Anyways, I'm basically repeating what I've said in the Apexi Power FC Vs Greddy eManage thread.
The above should point you in the right direction as far as a starting point is concerned. just don't expect your N/A Skyline to perform like a turbo Skyline, and don't expect huge results for your dollar spent. N/A performance is about relieving as much restriction as possible and trying to get air in and out of the engine efficiently as you don't have a turbo forcing massive amounts of compressed air through it.
Ps. If you want to know more about which exhaust to buy, what size etc.. I'll tell you know that it's been asked more times than I can recall, just do a search for that one ;)
But before you stroll into the first store or web site and tell them you wanna buy, have a look for second hand items. They are a buttload cheaper and good quality parts in good condition can be easily found.
that photo is mine... i found it and brought it to SAU first :)
That clicky cracks me up every time i see it. The funny thing to, the second page that is found is a link to the sticky in this forum..
Me thinks that someone was telling lies about the search button....
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
