Hi everyone.
I bought a CAMS approved fire extingusher, so i could enter track days. :banana:
My plan was to mount it in the passenger footwell, but there is a bump where the exhaust passes making it a tight fit.
The car is a 97 Type X 180sx.
Here is some pictures of trial fitting.
Any suggestions on where I can mount it?
Cheers
https://www.sau.com.au/forums/topic/256719-fire-extingusher/
Don't you need to be able to get to it pretty quickly if need be? If so I would mount behind the drivers seat on the B Pillar, that's where I had it in the rally car :(
If you braked suddenly or crashed, wouldn't that just fly off and make a crater in the back of your skull?
i've tried to put the fire extingusher as in pic.3 but it is very hard to reach it from the drivers seat with the seatbelt on, so it is not very likely to be a practical mounting point :(
Ummm... if my car was on fire, I would not keep driving with my seatbelt on, but stop the car and undo my seatbelt. Just personal opinion though :laugh:
Ummm... if my car was on fire, I would not keep driving with my seatbelt on, but stop the car and undo my seatbelt. Just personal opinion though :(
Me too lol
Another good spot is on the floor behind you just under the front of the rear seats if that makes sense. Drivers or passengers - which ever is easier for you to reach..
I was thinking of mounting it on the drivers side, but was told that it is not a very good idea if it explodes :( (not sure how many cases are there of that happeining) :laugh:
I tested reaching the extingusher with the seatbelt on, coz just in case your seatbelt is jammed or something after a crash and you mounted your extingusher too far.
I guess i could mount it on the side in the passenger footwell but also but a carboard-cutter knife or something in the center console just in case the seatbelt gets jammed.
As long as you don't have a 20-year old fire extinguisher corroded to the max, it won't explode.
In the event that pressure builds up inside the canister for whatever reason, there is an automatic "Wastegate" in all extinguishers that lets out the pressurised contents once they reach a certain pressure. I think mythbusters threw an extinguisher in a fire, and it didn't do anything, thus debunking that myth.
In the case that an explosion so violent does not give the canister enough time to vent through the wastegate, I would say, you're dead in the first place anyway.
Under the drivers seat is probably the best place to mount it. If it does explode, you have the cushioning of the hard flame-retardant recaro seats and your own derriere. If it is in sight, it will likely kill/blind you. In any case, an explosion in the cabin is probably lethal in any position.
this is legal for track.
use nuts and bolts, not self tappers.
the only place you can put it where you will reach it with a harness is on your centre console. putting it under your seat makes getting to the back very hard.
Mine is in the exact spot as Ryan's, near the centre console. Personally with a harness I reckon it would be one of the easiest locations to reach in an S13
Err no! I suppose if it wasn't mounted well it could fall off but it would hit your seat not your head! Unless you are a little person in which case you'd be propped up to see over the dash.
Seriously it fits well there, you can get to it with a tight harness on if need be and it doesn't interfere with anything, you can even mount it there with a cage!
Mines on the floor in the front between the seat mounting points under the seat on the drivers side.
The standard seat moves unrestricted as if it was not there.
CAMS scruitneers love it as i can reach it with a harness.
thanks everyone :D
I will trial fit it in the driver footwell tomorrow and see if i can still slide the seat with no problems, hopefully it all work fine
hopefully get my shit together to enter the DECA on the 28th
on the offtopic, does anyone know where i can buy some Lucas(TWR) Grand Prix RBF600 brake fluid?
Cheers
    • Make sure you use the spherical bushes** on the lower arms, ifyou do that. ** at least, if not the whole replacement lower arm.
    • The tap for coolant flow control will be stuck open. It's not just the air door motor that dies.
    • Not really, but the heater box is pretty simple mechanically....if the door is one way the air bypasses the heater core and if it is the other way it goes through it for warm air.  If you are sure the actuator you moved manually is for the heater mix (there would also be one for output air direction) then I'd take the heater box out and see what is happening (you'll have to regass and re-coolant the systems afterwards) BTW pp724 onwards from the GTR workshop manual cover the system in good detail, it is probably worth checking. I think the IAT sensor might be a problem electrically for getting cold (if you got 24 error code not -24 it thinks the incoming air is -50c) and it covers how to test the sensor (although most likely it is either not plugged in or a wire is damaged)
    • Use the GKTech subframe bush and bring your subframe 10mm closer to the chassis. You'll need to fix an exhaust hanger to suit. One of the best mods I've done.
    • You'd really have to pull it apart further to know, it least you can be confident that the one heading to the back is not connected any more. There was once a ground on the shifter seal mount too, your head unit issue could be that simple
