Thinking of upgrading to different Intercooler when the new turbo goes on about a months time. Includes Intercooler about 600x300x75 maybe a little larger and pipes to fit standard setup. Silicon hose pieces and proper clamps.
Looking for the $900 mark.
Am looking for Adelaide buyer however possibly could be posted.
Refer thread for pic: South Australia EOI Intercooler.
https://www.sau.com.au/forums/topic/25717-eoi-r33-intercooler-kit/
sounds good. any idea about the difference in piping between a 33 & a 32.
have you got any pix of it installed in the car (i'm assuming its still on the car).
its a slight pain that i'm in sydney but if it will fit to a 32 without to much trouble i'm interested
DESCR8 - Sorry thats a bit cheap. I would keep it at that price. I may consider posting it for $850. And removing it earlier.
cul202 - The piping wont match a R32 one might however R33's are side by side and R32 end to end. (entering the engine bay). They may be able to be changed. Pics are on South Australia site under same heading. I cant double up pics as a forum rule and am not sure how to put in a link.
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
    • Hi @Chupapy i had several leaks from coolant pipes being corroded, i also had one leak on back of the head onto transmission. For me that leak was from the turbo water line. Follow the line to the back of the head The hose and metal pipe had perished these are the best pics I took of it at the time
