Originally posted by fane
i would like to congratulate my mate pete for buying his first skyline... with a bit of convincing i converted him from a series 6 rx7 to a yellow r32 gtr with a trust kit....
haha! the workshop that serviced that gtr told me the owner was switching to a mazda rx7 once he sells it
Well I heard a rumour that Hanson from x-speed was going to buy this car when it first came into Australia but looked at it and engine leaked oil and gearbox was shot.
But thats 3rd hand info.....dunno how true it is. I guess the guy should give Hanson a call and find out. Hope its not true for his sake.
But yeah it has a way angry clutch so it might just be that.
the guy he bought it off cant afford his school fees at uni and because his dad is paying for it his dad told him to sell the car and do his honours....then he is going back to singapore... but thats just what the guy told me....
clutch definately needs adjustment....evo r put a new clutch in but put the wrong fork or some shit i'll let you know as wee find out info but pete figured if it just needs a new clutch or some shit like that then its still a cheap gtr....
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
