hey guys
when i bought my car the previous owners gave me the xenon with it. its still got wires attached to it but i have no idea how to connect it up.
can anyone help me install them please???
payment can be a nice chilled slab of what ever poison you drink
ta
Ash
https://www.sau.com.au/forums/topic/257398-help-with-xenon/
actually just did some reading. would be better to get aftermarket HID's as the ballast would have been removed from the headlight along with oter components that the car came with from fatory.
all good thread can be closed sory lol
https://www.sau.com.au/forums/topic/257398-help-with-xenon/#findComment-4430318
  • 1 month later...
holly crap i forgot about this until today when my left headlight went out.
well this is what the previous owner gave me same things for each side
the back of my headlight (passenger side)
and the light itself
now i have figured out the wires coming out of the xenon with the metal mesh thing around it will joing onto the other end thats still sitting behind the headligs atm. what is the yellow plug with wires for???
i would like to get this done hopefully this weekend so any help from those who has done it will be great. be even better if i can bring the car to you and if you can do it for me??? :D
and yes i know i have chubby figures lol
https://www.sau.com.au/forums/topic/257398-help-with-xenon/#findComment-4483514
fark it cold out :D
anyway took off hes headlight but hes xenons are different to urs, maybe because its a NA
but the yellow wire plug should go into the resistor and the 2 wires should go into the back of the middle globe, there will be a rubber gromet with 2 wires there most likely.
actually shouldnt be to hard to fix, solder the globe wires and then plug in the yellow wire plug and solder the other 2 wires
edit: ill be at my missus' saturday in lalor if you want me to try and fix it
https://www.sau.com.au/forums/topic/257398-help-with-xenon/#findComment-4483582
fark it cold out :D
NA's didn't have xenons
unless its a gt-v maybe?
what do the parkers look like?
a circle, or a square?
https://www.sau.com.au/forums/topic/257398-help-with-xenon/#findComment-4483587
fark it cold out :D
ye i figured out where the other wires go apart from the yellow on.
no you say should be plugged at the back of the light.
this is the back of the light here
i dont see no plugs where it will plug into
https://www.sau.com.au/forums/topic/257398-help-with-xenon/#findComment-4483593
im thinking the yellow plug could be connectors for the headlight adjustment from inside the car.
prob be easy to pull the headlight out and see if anything else is tucked in there.
thanks anyways nick. it is pretty cold outside lol
https://www.sau.com.au/forums/topic/257398-help-with-xenon/#findComment-4483602
r34 xenons dont have washers, so they are illegal
ok fair enough. i wondered why they were removed.
thanks for the info.
im not in any hurry removing mine though :D .
sorry for jumping in your thread like that ashneel.
https://www.sau.com.au/forums/topic/257398-help-with-xenon/#findComment-4483604
    • I’m here solo don’t have any hands to help so haven’t hit it with a timing light
    • When you crank your car, and hit it with a timing light, can you see a steady crank timing?
    • Oh, forgot to add, A few months ago I was getting mixture codes and the car was using crap loads of fuel. You could smell the unburned fuel in the exhaust, it was crazy strong. Economy was over 17.5 l/100 and usually around 19. I smoked the engine and found a leaky CCV hose which I replaced and then I replaced my two pre cat O2 sensors, I also replaced the MAF. This fixed my mixture codes and improved my exonomy but I'm still 14 - 15 l/100 when pottering about town so something is still amiss. Throttle response is much better and it has more pep but I'd like to know why it's still so thirsty (and I'm hoping that whatever it is gives me a bit more poke).
    • Car is on factory injectors/z32 maf/ q45 throttle body/ z32 ecu with nistune
    • Hello all, currently finishing up a rb25 swap into my s14. Having issues with starting, car has spark (confirmed by pulling a plug and watching it spark), has fuel(confirmed by checking pulse/voltage at injectors all spark plugs are soaked in fuel). Car cranks over and pops into the exhaust with a heavy fuel smell but no attempt to start or run, I have torn the timing cover off and triple confirmed timing, turned the CAS in multiple spots both directions, attempted to start with coolant temp and maf unplugged, checked my fuel lines and made sure they weren’t backwards, checked voltage at cas/injectors/coilpacks, made sure all the grounds in the harness are connected and added a few grounding straps (1 from chassis to block, 1 from chassis to head, and 1 from chassis to igniter chip) I am getting stumped here. As a last ditch effort I made a full grounding harness tonight that’s going to run from the battery and add an extra ground from the battery onto the coil pack harness/igniter chip/ intake manifold/ Wiring specialties harness ground/ and alternator. I’m hoping maybe the grounding harness will fix it here but posting here to see if anyone has any other ideas on what else I can check. My fuel pressure is unknown right gauge will be here tomorrow.  IMG_3206.mov
