hey guys,
recently bought a rebuilt HKS 2530 turbo to go on my RB20
im just wondering what injectors i should use,
ive seen people using GTR injectors but id like to get some brand newies instead
ive been told sards need to wired in and i cbf'd with that soooo any recommendations?
also will be installed with a pfc tune if that makes any difference..
cheers in advance for any help
and yes ive searched all i can find is people using 2530's on their GTR's
Kyle
https://www.sau.com.au/forums/topic/257442-hks-2530-on-an-rb20/
Just use the some GTR injectors slacker, get them cleaned & flow tested first. They drop straight in, only extra bit of work you need to do is the resistor pack but even a 10yr old girl could do that
They will flow plenty, more than enough for the power your 20 will put out so no point going bigger
Do the correction on the PFC & your set to go for a tune
if you dont want gtr injectors go with nismo 555cc, collars should fit straight up and you'll have no problems. also i'm assuming u have upgraded your fuel pump for the demands of the turbo? cheers h
CA18DET injectors, i believe they are 380cc you can get them almost free, they fit straight in and they do not need resistor pack (correct me if im wrong), just get them flow tested to make sure they are working fine. Will need full tune however and new o-rings are recomended, source from nissan
Edited by Ceffy_SA
Off the top of my head I believe CA18 injectors are 340cc & are still low impedance injectors (same as RB26 injectors) which means resistor pack is still required if running them on an RB20 as RB20 uses high impedance
As far as I know, S13 CA18DET run a resistor pack standard similar to the GTR, that's why GTR injectors are a quick easy upgrade for CA18's
Correct me if I'm wrong :)
Correct me if I'm wrong :(
Corrected...ca18det injectors are 370cc...
cheers guys
ive been reading rekins thread of him installing gtr injectors and he seems to be having trouble with them fitting straight in (he needed to trim some of the plastic off) why would this be?
do r33 gtr injectors drop straight in or just r32 gtr?
  • 1 month later...
Yes all rb GTR injectors will drop in (you will still need ballast resistor), the R34 ones are natural metal colour, not painted black like R32 &R33 GTR ones, my advice try and find newest or best condition ones you can, one of my GTR injectors first time round started to leak even after getting cleaned and tested, ended up having to buy another 6 because no one would sell me a single or pair, all 6 were cleaned & tested again with new rings, pintels & baskets.
Nothing you can do to repair a leaky injector and a leak wont necessarily show up during the cleaning process, if i had to pay for labour twice it would have been cheaper to buy brand new nismo ones off the shelf.(not to mention cost of lost fuel driving the car around for 2 months before i could get a day off to get it fixed)
Don't waste your time with the red rx7 ones or sard injectors, they have crap spray patterns that don't atomise the fuel properly, leading to crappier fuel economy over nismo ones, but i am sure others would argue that point.
TOTALLY AGREE.
Been having ongoing issues with my GTR injectors cause they were old. I had them all cleaned and tested, and have had issues with 2 of them so far.
Lucky for me, I have been able to find individual ones, but it has been a pain in the ass troubleshooting and fixing them. I think I have taken the injectors in and out about 6 times now.....at least I have gotten good at it now ;)
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
