Got a set of ku36 a few weeks ago from local tyrepower shop in Albury.
Prices were as follows
235/45 -$200
255/40 -$285
245/45 -$245 no stock at the time
Hey Luke,
Thanks for the info. Good prices there, but after factoring in freight and fitting costs, its probably no real saving to buying them locally unfortunately. How do you find the Kumho's? Im thinking about getting a set for the road now anyway.
Edited by SLVR32GTR
I have Kumho KU36 on my Supra because I track it fairly regularly and only have one set of rims. Good tyre for what they are, but they're not a semi slick. I use 245/40 and 275/35 * 18. I've done 2 Lakeside Sprints, 1 QR Sprint and probably 5000km of street driving since Sept last year.
On the road:
they're not loud, good in the wet, but tramline alot (I run a fairly agressive alignment too so its hard to say how much of that is caused by the tyre).
On the track:
- Only really good for about 3 laps before the rears go off. This is on my Supra remember, and my rears get a fair workout from my driving style... Might last a bit longer on an AWD car. I'm careful not to warm them up too much on the warm up lap as they work best just off cold. That's not to say they're better than a cold semi slick - they're not.
- They need alot of pressure like a street tyre. I run between 36 and 40psi cold. I found there was no point aiming for a target hot pressure because by the time they get hot, they're past their best. Better off aiming for a hot lap straight off the cuff with these tyres. Mine generaly come on the 1st or 2nd flying lap. byt he end of the 3rd lap you have to start being a bit more careful with the right foot.
I'm really happy with them on the Supra. If you only had one set of rims and wanted a jack-of-all-trades tyre,I'd recommend them. Or if you just want them as a really good street tyre and aren't really concerned about wear, then yeah go for it.
Edited by hrd-hr30
Thanks for the info Harry.
I just talked to Alan at Z Car Workshop here in Briz and i can get the following prices for Silverstone Tyres
FTZRR in 235/40 (largest in 17) for $375
s585 for slightly less than $375 (no exact price)
Am going to go and have a chat to him tomorrow hopefully and see what they are like, as i havent heard or read much about them.
Try Track side tyres in melbourne. Craig is the man to deal with. 18 months ago we could get RE55's landed in townsville for 420 each for 255 17s. Very helpfull and if i was not getting toyo 888s cheap through my friends shop I'd use him agian for sure. Obviously with the exchange rate they won't be anywhere near that now but his service was outstanding.
I have only run them at a winton fun day so far, sprints start again in a few weeks.
Like Harry said tramlining can be a problem, but overall i'm really happy with them.
Harry how have you found the tyre wear so far?
Tony,,,I really don't know much about which tyre you should use,,,but what I will tell you is very simple.
If you want to go fast at hillclimbing you have to use the softest tyre you can find. Grip on cold tyres is what it's all about.
It's no secret that all the libre/sports sedans run avon slicks,,,why,,,because there's no way you are going to get heat in the tyres,,,so the only other way to get grip is a softy.
If I was using a Skyline for cllimbing and had a spare set of wheels I would buy a durometer and start testing tyre hardness.
The only problem is they will end up being hillclimb tyres only.
Neil.
Thanks for the replies guys. Because i want to use the car for track days as well, im going to have to compromise and go a med-hard tyre im thinking. I will keep ringing around and getting prices and info and see how i go.
  • 1 year later...
hi, there :happy:
1) what does tramline mean?
2) i have used Firenza Sumitomo before and they were fairly loud. How's road noise on the KU 36 compared to this?
3) does KU36 have some sort of "rim protection"?
thanks
On the road:
hi, there :)
thanks
1) follows the contours in the road
2) never driven on the Sumitomos, so i can't say
3) yeah, pretty sure they did
  • 1 year later...
hey guys,
i can get kumho ku36 or other semi slick tyres cheap as i work for a tyre company and get cost price for tyres if interested??
ku36 are a good semi slick tyre there much better on a awd car then a rear wheel drive.
thanx
hey guys,
thanx
I'd recommend A050's - softs are ok for just hillclimbs on road going R32 - too soft for supersprints - we find mediums have done the job on both R32 & R33 at all NSW, Aussie and time attack events.
Tow out on the front, bitta tow in on the back around 28psi cold.
Enjoy
hey guys,
thanx
id also recommened bridgestone re070 as a 22545r17 has a speed rating of w=270k which are a good tyre with the write alignment
They do not even compare to a proper semi like the AO50
    • Per Mark Roberts of Sonictune: Mark Robert Author At this time, no. No ETA either 2016-17 models. You will be able to purchase and install a 2018.5+ TCU though   TCU purchasing and pricing info! As we near the release of TCU tuning, I am going to answer some questions I get asked often.   What do I need for TCU tuning? At this time, you will need a 2018.5+ TCU to be able to tune. If you have a 2016-to early 2018, you will need to replace your TCU with the newer version. One good way to know if your TCU is good is if you have auto upshift in manual mode in 1st gear around 6500 rpms. If your manual 1st gear goes to 7k rpm and will hit the rev limiter unless you shift, you have the older TCU.   Why do I need to buy another ecu license/phone flash if I already have it on my ECU tune? The TCU is its own computer module. It is completely separate from the ECU. Because of this, you will be required to purchase a TCU license and, if your tuner has it, the phone flash license required to tune it via phone/bluetooth.   Do I need TCU tuning? TCU tuning is NOT required. However, the faster your setup, the more it will assist in track and dragy time consistency.   If I’m ECU tuned by (tuner A) can I get my TCU tuned by (Tuner ? Yes, since it’s a different module and a completely separate flash, you can have two different tuners. However, it is highly recommend that you have both tuned by the same tuner. For me, my TCU tuning will directly complement my ECU tuning style and features and running my ECU and another TCU or vice versa MIGHT cause some issues. At this time and for the foreseeable future, I will only be tuning my current ECU tuned customers TCUs.     I have a SYVECS AWD controller. Do I still need it? Yes! The AWD controllers main job is to control your AWD system. However, with TCU tuning, you will no longer need the auto-shift function as that will be done through the TCU. The AWD controller will still be very beneficial for racers looking to maximize traction on the launch.     Shift schedule changes: holding gears longer at lower pedal input as well as max shift rpm changes. Please note, the new ECU race rom coming out will address 90% of the shitty drivability issues these cars have through custom maps from myself and Racebox—as well as others I am sure.   Increase shift speeds: as seen in the videos I’ve been posting, the TCU shifts much faster once tuned.   Increased shift pressures: as also seen in the videos, much firmer full throttle shifts.
    • The fancy pants red shock tower brace is finally incoming from MX5 Mania, getting it shipped from 'Merica has been a long and problematic process, and GWR, the 'Merican supplier will not ship directly to consumers outside of the US, Mania basically had to order a heap of them, the colour choice was silver, or red, and we all know anything red adds 5 killerwasps of dynotorques..... Whilst it does fit over a 2.5, and I've seen a few photos and videos of it being installed and fitting, google also says it might get real close to the FAB9 intake front runner, people in the US says it does fit with the FAB9 intake, except for one person who said it slightly touched.......so there is that.....LOL..... As it seems that I am the first in AU to have this combination of parts there's no local knowledge about fitment, so I'm just a willing guinea pig in this endeavour, I'll cross my fingers and toes and hope for the best In other news, I ordered stuff from China  on the same day I ordered the 23° silicone bend from Victoria, the stuff from China arrived a day ago, the 23° silicone bend is still travelling around Australia thanks to Australia Post, and "may" be here next week
    • Very good news...I contacted Racebox about it last night. My car is a 2016 so remains to be seen if it is compatible, requires a TCU swap, or is impossible.
    • What ECU are you running? This is probably the biggest question. If it's a PowerFC, I'd probably change the ECU and get something newer that will handle the injectors in a nicer way.
