if you wanna win best display i suggest you pull out some silk sheets or whatever those crazy fools like to put under their car.
if its not too hot night kids model car is coming out and some of gtr 32 obsessive collection of goods
  • Replies 354
I'm in :wave:
bring the camera for lots of photos too..lol, see if we can manage "not" to get sunburned this time..lol
do we get to park near the dragon 180..lol
im gonna try and bring sunscreen this time round............
put me down as a maybe if you promise not to discuss awards, hell i dont even wanna see any of you guys near them when they announced :D
yes dan.
im d-d-d-d-ownnnnnnn like a clown with bells on
sweet as brew..............minus the dildo gear knob? haha
Cara , Stupid thing is I had sunscreen hidden under my frozen water bottle in my esky, but forgot I had it with me!!!... grrrrrr
Is it possible to "not" park in a row this time? maybe something more appealing for a photo shoot ..lol
(I know they forced us to park in a row last time? )
do we know if they have a sound off in this one ? their website loads to slow here in the sticks on wireless..lol
Nah, if you want best display, sneak some Commodore badges onto your cars!
both wrong. stuff cotton wool into your arches so it looks like your cars doin a skid. judges will eat that shit up.
What's wrong with that?!
Me at All Japan Day 2008:
That's why they didn't have judges. They thought "shit, with that kind of quality on that GTR... we better cancel all judging, otherwise that GTR would be the winnah for the best fake 4WD skid"
im pretty sure that yes they will have a sound off there was one last year.
fingers crossed we will have a bit more of a say on how we want to do the display. i was told at smasa straight line thats it.
Vu - see my original post about entry fee...........not sure bout times etc will be similar to SMASA a pack will be sent out with ur entry number etc
and guys please keep it on topic!!!
im in if theres room cara,was in it last year so why not again haha! when organising for our autobarn display last year they were pritty good with how we wanted it to go and where,as long as theres physically enough room they are generally really good.i still have the contact numbers for the guys that run the show so if youd like i can get in contact with them and find out what sorta arangment we can have.
hey guys
with paying ur entry fees u will need to fill out and sign ur entry form.........
so how bout we all meet up at vilis next friday night and ill get some entry forms printed off and then u can all pay and fill out the forms then??
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
