  • Replies 42
People who don't seem to realise that they were given TWO ears and only ONE mouth for a reason. And that if you use them in a similar ratio you just might learn somrthing now and then.
Oh, my other fav' is the "5 minute expert". Dickheads who exemplify the expression "A little knowlege is a dangerous thing." Some poor noob will take it that the 5min is an info-god ("No, no, ceramic turbos are stronger than steel and can handle 20PSI no worries" or something like that) and actually follow their advice.
people that say one thing and do another
people that stick in the right hand lane on the freeway
and dont move over when u are right up there ass
chicks that give me dirty looks when im driving
people that stare
dick heads that try to drag u of every traffic light
well the law is u cant stay in the right hand lane right?
the law is keep left unless overtaking
even if u are doing the limit
if someone comes up behind u arent u supposed to move over?
if you are doing the limit then the person behind you must be breaking the law, if you are overtaking in the right hand lane and doing the speed limit and someone is hooning up behind you keep doing the speed limit and make them wait :D
but people generally arent over taking
they sit their fat asses in the right lane and stay there
so if someone is up ur ass then tough
if u choose to be arrogant then cop the abuse
in this situation both a breaking the law
person A for not moving over
and person B for speeding
this is a very popular situation for road rage to develope
but law abiding citizens like myself never break the law :angel:
SAU does not condone breaking the law
:D
Confession:
Driving 60kmh in 60 zone (well maybe a little more) on right hand line. No one on the left.
Dickhead behind me flashing long beams.
On left line potholes missing surface and other uneven road conditions as you can see on many on our roads.
Well I stay on my right if the dickhead want it can take me on the left ( they usually will not, why should they demage their suspension?).
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
