Hey guys,
Ive put tomei cams in my current motor, and to my suprise had to buy new buckets as i didnt realize they have a different base circle to stock cams. Turns out im not the only one who's fallen for this trap.
As an example, i thought cams would cost about 1k, but then add the buckets and thats 2k. Now, if HKS (for example) cams are 1400 but dont require buckets then you're about 600 infront overall. Make sense?
So, this thread is to hear peoples experiences with cams - who's had success with what etc but more importantly; Do JUN cams require bucket/shim/whatever changes? I know springs should be changed to match lift - but other than springs, what else needs to be changed?
I need to get cams for the next motor im building, which is underway currently (starting from bottom end first) and would love to just get the right cams this time without spending huge amounts of coin
Thanks everyone :wave:
Hey guys,
The base circle dictates what size shim you require to get the clearance right...JUN like to tell you to use a really thick shim to make this clearance right...i dont recommend this...the thicker bucket is always the better more reliable way to go, which is how Tomei do it. PM unique1 and ask him what happens when you run a 'tall' shim instead of the thicker bucket and a reasonable size shim...it will cost you a lot more than doing it right once. Please don't take short-cuts mate...id hate to see you bitten again.
Edited by DiRTgarage
I have held off on cams due to this same shim/bucket issue, cam upgrades dont seem to be such simple "drop in" jobs as the kits suggest.
32mm base circle cams are a 'drop in' nothing else. Id suggest anyone putting 32mm base circle cams in to do a quick bucket clearance check just to make sure its ok.
rb25: Tomei 256deg cams and 8.8mm Tomei springs are a good fit ! :(
rb26 - dunno sorry, but something like the above would probably only be "mild" on a built rb26. 272's then, perhaps.
what turbos, bottom end combo will the head be utilising, plz ?
yeap i've been bitten by using JUN cams with standard buckets and big shims. Destroyed the entire head when the sim popped out of the bucket. Had to do it all again. :)
yeah...another one eh...bummer.
if you look on the JUN website it lists the 'tall' shims they advise you to use. In my opinion this is a dangerous practice and has been proven so with many shim 'pops'. Did you use the JUN offset retainers as they have 2 offset types that take up 0.5mm and 1.5mm clearance respectively?. With a 29mm base circle camshaft if you use the 1.5mm offset retainer and the 1mm thicker Tomei bucket you only have to use around a 0.5mm thicker shim than standard. This is the best way to go if using 29mm base circle cams.
Exactly
From further investigation it looks like JUN sell a package including buckets etc
rb25: Tomei 256deg cams and 8.8mm Tomei springs are a good fit ! :)
HKS GT-RS's
Full built RB30 bottom
i wasnt the person who had issues Dirt it was Public Enemy i think u were thinking of. I run the biggest lift cams Jun make and never had an issue in 2 years+ of over 550rwhp and 8500rpm+, i recently bought a set of Tomei buckets though after hearing of the possible dramas, just to keep my mind at ease.
Edited by unique1
So until then you used standard buckets?
yes standard buckets and bigger shims from precision shims. the shims are pretty damn thick due to the small base circle so it isnt ideal at all, but it works none the less, but im changing them over just to save a disaster arising after hearing about Public Enemy's dramas.
yeah i used the JUN cam package that includes cams, Titanium retainers and type 2 springs. My understanding was that this package would be put together to be compatible with the base circle of the JUN cams. The shims were huge from memory and destroyed the retainers when they came out and then the retainers cracked the standard lifters which messed up the casting of the head. Lotta $$ porting and polishing that head and it went in the bin :P
Ah well live and learn.
Anyway now using Tomei 272 10.8 cams, Tomei buckets and Tomei type C springs.
So far so good but only a 1000 odd Kms on this step up.
    • Kittens in first to claim dominance of the residence, then puppies later From past experience, the other way around can be problematic to say the least  Those weird "Dobby looking"  little kittens are not cheap....LOL
    • At least yours have parkour down pat. One of mine will still trip over his own shadow and fall over... He's a special type of cat... Ha ha ha
    • The question then becomes - was there any fluid coming from that hole before you did the rebuild ?    You may not have noticed, of course.   Depending on how you did the rebuild, the possibility has to be considered that somehow (cleaning ?)  fluid entered that hole and is now being 'forced'  out by small movements of the proportioning valve.   From the factory, there's actually a small rubber plug in that hole but with age and under-bonnet heat it's quite common for it to 'go missing'.  That rubber plug is designed to allow the venting process but also to prevent 'stuff' getting to the area (prevent corrosion, etc).   The plug is also not available as a spare part AFAIA. Personally I wouldn't race and buy a new master just yet but keep an eye on the area to see if the 'leak' continues.   If you're concerned about brake fluid damaging nearby paintwork, cable tie a piece of suitable absorbant material over the hole and remove/monitor occasionally.    Operation of the proportioning valve and the brake master itself won't be affected, but also keep an eye on brake fluid level, of course. In terms of a new master, the genuine part is getting expensive, unfortunately.  Amayama is showing AUD900+.   I was searching recently and there's an aftermarket part available from Japan made by 'Parts Assist': https://zenmarket.jp/en/yahoo.aspx?q=BNR32%2bBM50&p=1 Whether it's any good I have no idea, although in my experience Japanese aftermarket stuff is pretty good quality-wise.   The above site allows overseas buyers to purchase stuff more easily from Japan but there are fees and shipping costs, of course.   The original Japanese seller page is here: https://auctions.yahoo.co.jp/jp/auction/p1197401228 Copper/Nickel is fine but I still prefer bundy tube and it's also cheaper.
    • Your chihuahuas look weird!
