Are you letting the wolf ecu controll your boost?
If you are a gauge is not necessary, as the wolf will keep it at your desired setting and if something does go wrong i am pretty sure it has overboosting protection.
Personally, i am not into gauges, so i do not see the need for one.
GOOD LUCK with the install and tunning. I have been very pleased with the unit myself. Only one small glitch, i can not keep the engine running with my turbo timer :D, but hopefully that will be sorted soon.
https://www.sau.com.au/forums/topic/25772-wolf-question/#findComment-547524
Cold start and idle are purrrrrring :P
- the problem was a combination of a few things :
1/ Oil was a little too thick on cold start
2/ Was only really bad in winter (cold mornings)
3/ Slight tune adjustments
Now that i have changed the oil, mornings aren't as cold and the tune has been adjusted, the car starts on the first turn (be it a second or two longer than factory).
The solenoid was for the boost, and i have hooked up the factory solenoind again, the wolf just pulses this off and on to maintain the desired psi.
I tried putting a biggish cap. on the ingnition wire to the wolf, to give the timer that fraction of a second longer, but without success.
Display has been mounted where the ashtray was, and the keypad relocated to the glove box. Looks really neat and works a treat :(. Now i have the p.i.n. security code, fully operational ;).
https://www.sau.com.au/forums/topic/25772-wolf-question/#findComment-548430
Nice work Al! Love the idea of splitting the unit...
Im fair happy where iv mounted mine though, while iv made it detachable so as not to draw too much attention :(
Last thing i want to do is explain to the next cop what that hand controller is :D
So your using the factory solenoid to control boost? impressive cos we only managed to make it for at 10psi, after that it just wouldnt control boost so we had to installa bleed vavle..now im about to enquire for a 3bar solenoid from AEM
Howd u manage to make the factory solenoid work with the Wolf? was there anything to it?
https://www.sau.com.au/forums/topic/25772-wolf-question/#findComment-548920
    • So either way it is gearbox out and look what is wrong?  I know about the input shaft bearing. Even before swap/new clutch the it sounded exactly like this: So is that inout shaft bearing or the other was installed backwards?  And can some please tell me the part number for that input shaft bearing? The gearbox is small box from R34 N/A and number is FS5W71C. Thank you
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
    • D2 and Ksport are essentially the same thing and basically just generic Taiwanese manufacture. Better than ChinaBay crap, but... not top shelf. Öhlins have got to be some of the best dampers around, so likely to be a good option. It's going to get to the point though where I suggest you buy from Oz. We have at least 2x excellent options here. If I were you though, I'd be talking to KW about doing something for the R33. There's bugger all difference between that and the 32. In GTR land, anyway.
    • KW only offers a set for the R32 GTR. Popular options are D2 racing, Ksport or Öhlins. I have a D2 Racing coilover set, though I don't know for sure which one.
    • Well, the good news is you have more than one very good option for new coilovers in and around your country. Worth the drive over to KW to talk about GTR stuff.
