Help! replace r33 rear spearkers
there should be 2 bolts holding the bottom of the rear seats, undo them then you have to lift it up quite hard.. it should come out. there should be another 2 bolts holding the rear of the seats, undo them. Now take the parcel shelf off gentally as you dont want to snap it. unscrew and replace speakers :D
my parcel shelf was tuff to get off, had those baby seat bolt thingys in it when it was complied. You might have to unbolt these through the boot. There are other clips you need to unscrew through the boot as well.
I couldn't fit 6x9s because the left side speaker touchs the battery.
If you intend to fit a sub, don't bother with the 6x9's.
Personally, i bought a "top of the line" set of Hertz 6" mid bass woofers for the rears, does the job :( (After all it is a performance car and you don't want to weigh it down with subs, etc.. ;) )
Only want to say that you don't have to cut the metal to fit 6x9's. Just have to put them in on an angle to follow the existing "D" shape cutout in the body.
I have put Sony Xplod 6x9's in (these are not particularly slimline or anything). It is fiddly but it can be done.
I posted details of this some months ago. See attachment
Enjoy
Factory R33 S1 speakers are 6.5" all round! . After listening to others on this forum say 6, I went out a bought 6s only to waste 4 hours making brakets to fit them properly :(
And yes, the backseat will need to come out before you can get at the rear speakers.
Do a search in the Car Audio section :uh-huh:
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
