We can't wait any longer to find an ecu for our S2 Stagea auto. The std ecu couldn't be fixed (BUGGER)! Have rang lots of wreckers with no luck and my local nissan can't even get back to me. We are going to have a Vi-pec ecu board fitted next week. It is going to clean out the piggy bank but I am looking foward to driving wagon again. I am going sell the Apexi SAFC and Jaycar boost controller that are wired in. I will sell Apexi Multi checker also if it can't be used. It will be interesting to see what wagon goes like. I have just o'hauled head after head gasket letting go on no. 6. At same time I match ported manifolds to head. While in machine shop they dedaged seat to port machining steps and smoothed chambers. I had injectors cleaned. I also fitted an adj. ex. gear at the same time as fitting a 100k km timing belt kit. Wagon allready had a k&n panel filter, full 3" exhaust and was running 10lbs boost. Head gasket blew 2 days before new years and wagon has been off road since. I am going to the blow cobwebs out once we get it tuned!!!
https://www.sau.com.au/forums/topic/257873-vi-pec-ecu/
Sounds exciting. I have been told that the Link (same as the Vipec) can handle autos (i.e. retarding timing etc during gear changes). I haven't taken it further because I can't afford one just now and I have found someone to make my ecu tunable but I believe you may need the top of the line model to handle the auto (but maybe not). I look forward to your results. If it goes well your car should fly with the stock turbo (more airflow for the same amount of boost) but you will also be set for a turbo upgrade in the future. keep us posted!
https://www.sau.com.au/forums/topic/257873-vi-pec-ecu/#findComment-4436361
I've been told the same thing from a Vipec dealer, which is good news because I was just told by the Haltech people that the e11v2 will NOT talk to the stock ecu. The only way to get the Haltech dropping timing on shifts is to attempt to intercept a signal from the gearbox when it changes gears and set that up as a flat-shift function in the Haltech :P
Keen to see how you go skidkid!
https://www.sau.com.au/forums/topic/257873-vi-pec-ecu/#findComment-4436617
surprised you didnt grab a chipped one from yahoo japan.
tested a S1 one recently, worked a treat, and the fella also had a S2 unit coming as well......
so they are around, used S1 or S2 ecu's chipped for Rom tune in Japan.
grab one, use safc to sort out the tune on your own car, and go from there? around $300 a unit.....
anyway best of luck
https://www.sau.com.au/forums/topic/257873-vi-pec-ecu/#findComment-4436717
I have been assured that the Vi-pec will run our S2 with an auto. If not I will not pay for it and I will have to hurt somebody!! Tangles; We decided not to go 2nd hand ecu because no warranty and Vi-pec can be tuned to our mods!!
https://www.sau.com.au/forums/topic/257873-vi-pec-ecu/#findComment-4437075
Ouch! :laugh:
$1760 for an ECU which is in my opinion one of the best available and is over $200 cheaper than a GTS-t Apexi Power FC which is quite a basic ecu compared to the Vi-PEC.
$750 for tuning
seems the going rate really...quality costs money
https://www.sau.com.au/forums/topic/257873-vi-pec-ecu/#findComment-4452631
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
    • Ok, disregard my “rate them” comment, sorry for my unrealistic input
    • OK, now we are ready to get started. You need to remove the air boxes on each side for clearance. The cover is straightforward, undo the clips on the top and lift the front cover out of the rest of the housing. If it is tight you can remove the air filters first. The rear section of the airbox is trickier. On each side you need to remove the Air flow meter wiring which is held to the airbox with a clip; you need to get behind the clip on 2 sides if you want to remove it without breaking it - unclip the harder side and pull on the clip with medium force, then unclip the easier side and it should pop out The airbox is held onto the intake hose with a spring clamp; you need to get a flat bladed screwdriver behind the spring on both sides and pop them outwards. When you have got them in the right unclipped place they will stay there and the airbox slips out pretty freely. Put a rag in the intake to prevent anything getting dropped in there, and also to prevent you seeing that the turbo seal is leaking oil (as they do). Then. The top of the radiator is held by a steel plate, it is secured by 2x10mm and 2x12mm headed bolts . Remove them and remove the plate Also grab the bushings that hold the radiator to the plate on each side so they are not lost!
    • Next, remove the upper and lower radiator hoses, both are held with a spring clamp. While you are under there, tackle the Auto Trans cooler lines.  Again both are held on with spring clamps, and as mentioned above you should cap them on the radiator side with an 8mm cap, and on the car side loop them with a length of 8mm pipe - this will stop you losing a dangerous amount of AT fluid during the rest of the job If you've been meaning to add a sender for AT trans temp, this is a great time to do it; put a sender fitting into the passenger side line as that is the inlet to the cooler/radiator.
    • Next you need to remove the intake duct (as with pretty much every job on these cars), it is a series of clips you gently remove with a flat bladed screwdriver. They do get brittle with time and can break, and I have not found a decent quality aftermarket one that fits (they are all too soft or flimsy and don't last either) but the nissan ones are a couple of bucks each (ouch).  Once the clips are off (either 8 or 10, I didn't check) you lift the intake duct out and will see the reservoirs Undo the line into the radiator side cap (some bent needle nosed piers are awesome for spring clamps) and then remove the 4x 10m nuts that hold both in place.  I didn't get these pics, but remove the line under the radiator reservoir (spring clamp again) then remove that reservoir. Then you can get at the intake reservoir, same thing, spring clamp underneath then remove it. BTW This is a great time to put in a larger (+70%) combined reservoir that AMS makes..... https://www.amsperformance.com/product/q50-q60-red-alpha-coolant-expansion-tank/ They also make an Infiniti branded and part# version if that is your thing
