Make: Nissan
Model: R33 GTS-T
Milage: 91,XXX
Transmission: 5 SPD MANUAL
Colour: BURGENDY
Complied? YES
RWC supplied?
Currently registered? Yes -- 11 MONTHS
Price: $12,000
Contact: Charlie
CONDITION: Excellent
PHONE 0418793736
Comments
BBS Forged Alluminum wheels - 17x9 front 17x10.5 rear
Near new tyres - Falken front Bridgestone Potenza rear
One scratch on the passenger side door
2x80 WRMS Response Amp, Response 6.5" Split Speaker system
Direct connect any audio device to amp
Strut brace included but not fitted
https://www.sau.com.au/forums/topic/257878-1993-r33-gts-t-12000/
Will swap for a motorbike + cash my way. Looking for anything learner legal such as CBR250 or VFR400, prefer these 2 models.
Only asking for 12,000 because the wheels and tyres were so expensive! This car handles insanely with stock suspension and takes off like a bullet.
Edited by R33LOD
    • Before all the EFR fan boys come in, have a look at: https://www.garrettmotion.com/racing-and-performance/performance-catalog/turbo/g-series-ii-g30-825-58mm/ It also comes in a T4 1.06 divided housing. I would dare say if you want response & also decent power, this thing would chop.   AND apologies, just re-read your post, you've already bought the turbo... whatever you do, make sure you stick with divided housing and proper twin scroll manifold.
    • People have got to stop doing that. ShatGPT is not a search engine. It is a hallucination factory.   I also would recommend the 1.05. The .83 will "work" for you , in that it will be more responsive, but I think you'll find that it won't be anywhere near as good running it out to 8000rpm as the big housing will be.
    • Decided for the first time ever I would tow my car TO the track day on the same working theory as bringing tools and spares "if I have it I wont need it, but if I leave it behind i will 100% need it" all setup and ready to go out and try these A050 for the first time First session showed I needed to stiffen up the dampers a touch but still managed a few 1:21's without much effort. things were looking good. Came in a dropped the tyres down  to 26/28 as they had gotten to 35/33C from 22C cold The first lap of session two I managed to drop into 1:20's. Then in the second lap into the second session. Coming into T3 and I suddenly lost brake pedal followed by some huge rear end vibrations and scraping sounds. Got it back into the pits after session ended and found this. in the attached video, all of the wobble is in the hub its self, wheel is mint, and bearing feels tight. lKXLqpd - Imgur.mp4   Deciding it was a bent spindle I tried to find bearing/hub assembly locally but was unsuccessful so it was loaded back onto the trailer i luckily brought it on to drag it back home
    • 1.05 you’ve gotta let it breath
    • You have to continuously fill it to avoid dry running. Personally the transmissions I've serviced have never been bad enough to justify doing this because it is definitely a pretty complicated and somewhat risky procedure compared to simply draining the pan, measuring what came out, then refilling with the exact same amount.
