Sorry A i may have miss read AMperformance makes a High Flow cat out of ceramic 200cell 4" body with 3" mouth awesome bit of kit $360 standalone or i think $250 with a dump pipe which is $360 for a SS split dump
Its kool man, ok well i got a dump pipe already, picked up split stainless steel one for 160. but that sounds good. Is there realli any difference between a metal and ceramic. i saw this one on ebay
http://cgi.ebay.com.au/ws/eBayISAPI.dll?Vi...E:X:RTQ:AU:1123
let me knwo wat you think apparently its flow is 550
your all leading him up the garden path....
refer post #9
then use post #2
and problem solved.
if your missues wont let you i have a $400 metal cat with very low kays ready to bolt on for $150
flows over 700cfm, best you can buy
pm me if your keen
Don't want to hijack the thread but does anyone have one of Am Performance's Split Dump front pipes?
If so, are they better value than the cheaper JJR ones sold in the trader section?
you cant compare the quality picture for picture they look the same but look @ the metals used and you will know Andrew only uses quality australian stainless not the cheap chinese rubbish
all flanges are stainless as well not like jjr dumps
Andrew is local so...
1) your supporting local business
2) if something is a miss then you can ring him and he will fix it till your happy
better value is hard to put a short term price on is $360 better value than $200 in the short term a lot of people would say no
i however say yes, and im not the only one but you (being anyone) need to make your own mind up
Or you could grab a 33 GTR factory metal cat, run one in mine, bout $100 from a compliance place. Good flow too!
ive said that basically everytime a cat converter thread has popped up.
1. go to compliance workshop.
2. purchase factory GTR cat.
3. ????
4. profit.
basically, gtr cats are win, and they cost f**k all as theyre normally binned when GTR's are complied.
Edited by scandyflick
Cheers. If it's built better and from better materials then in my book that's better value even at $360
3. ????
4. profit.
Dave is correct, only prob is trying to find an original GTR Cat cause all the ones you see that are complianced and stock standard have an aftermarket crappy one on them.
Like Dave said, go to an import house that does compliancing and start sifting thru their bins like a homeless person.
    • They are, a good friend of mine bought one to replace his blow factory turbo, running a Toshi Tune reflash. Just use their supplied water/oil lines and you're good to go. At the time, they were like $900 delivered.
    • This is an option for 100% bolt on, the GCG high flow -  https://gcg.com.au/turbo-charger-upgrade-skyline-gtst-2iu-xtrgts-s1.html Also, I'm pretty sure hypergear does a high flow that is 100% bolt on, it just doesn't make as much power as their bigger high flows.  Even if you get a hypergear turbo that requires you to chance the intake piping, it is a really simple modification. It can be as simple as a piece of silicon hose and you pop a filter on the end. It doesn't have to be some crazy pie cut titanium work of art intake pipe.  If you have the ability to swap the turbo yourself, you would be able to sort the intake piping out.
    • Just as a thought, if it's in neutral, thats your drive line disconnect, not the clutch. Clutch slip at the dyno with pedal fully out, is actually adding a second disconnect. So it's not a clutch issue if you're in neutral. Just a bit of friction dragging the output around while in the air.
    • The HG high flow is excellent, and costs about the $$ you're talking about. But it, and probably every other highflow, uses a diffeent core than the original turo, and the original Hitatchi core is quite long. So, I think it is inevitable that there is likely no such thing as a highflow that just "bolts on" with no other effort required. And the same is likely true for HG's outright replacement "bolt on" turbos (the ATR things). And the same is likely true for anything similar from elsewhere. I have no idea if the cheap Chinese/Taiwanese complete turbos from eBay/Temu/etc are as bolt on as they claim. I mean, they claim the bolt onto the NAs as well as the turbos, and we know that can't be "bolt on". But it wouldn't matter because I'm not buying a $169 4 psi turbo for anything other than a paddock basher.
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
