hey thanks for the replies guys..
Firstly, Nicky-poo, it IS the proper color i just adjusted the contrast seeing as how i used my iphone to take the pics and its low res, oh and Im not from sydney, im from a little town near Canberra on the NSW border..
Secondly, Lint, thanks dude, but it already has rims and cable ties lol..
  • 1 month later...
  • 1 month later...
  • 2 months later...
  • 4 weeks later...
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
