G'Day,
Background
I'm building up a budget gtr track car (if such a thing exists), I took it out once and did number 6 big end bearing.
I am now rebuliding it and have done all the standard fixes oil restrictor, head drain, extended sump and oil cooler. I will keep the revs down to 7800ish and just change gears to go faster (ha ha).
I am thinking of reusing my 115k oil pump (shock horror), I measured it up and the clearances seem ok.
My Question
I have read a bit on this topic and what I can work out is it seems all crank driven oil pumps (even Jun) fail due to crank vibrations/harmonics through either high revs or rev limited induced harmonics. What do you think?
If this is the case as long as I keep the revs down and don't sit on the rev limiter the standard pump (N1 pump with weaker relief spring) should be ok?
Am I mad or does this sound OK
https://www.sau.com.au/forums/topic/258105-why-do-oil-pumps-fail/
I think your plan sounds sensible. I have never broken an n1 oil pump. Just keep it off the limiter, have a crank collar and don't do repeated launches without loading up the driveline first.
If you look at the actual number of people who have had problems and how they used the cars you will see they don't fail half as often as the internet would have you beleive. And when they do fail they have generally lived a hard life first.
I sure wouldn't resuse a 100000klm old one in a race car when a new one is $400 though.
And do remove the backing screws in the pump and loctite them again before using it. They do sometimes come loose.
Recently ive spent a fair bit of money on my GTR and the last thing i want is to spin the bearing :S
ive never taken it to the track and i never rev it past the limiter.
How do i know when my pump is on its way out? when should i change it?
Smash the limiter, you'll break pumps... simple as that. That's what kills the pumps. Its not harmonics or anything else.
Plenty of track cars here using N1 pumps, over 350rwkw, no issues.
Don't smash the limiter, you wont have a problem
    • Or, is it a case of what it is like owning an R series Skyline? NFI what the previous owner has done or fiddled with... Ha ha ha After reading through this thread, I went on a bit of a research about the Q50/Q60. Now I'm quite intrigued by them! Is the AWD in them more like a WRX where it's always AWD, or is it more like the ATTESSA in the GTRs? By the sound of this TCU tuning, this sounds like a case of someone has made some real software for it, and you just need the right piece of hardware, and then you license that specific vehicle/TCU. Or is this a case of the software will be really expensive so only a few tuners have it, and you still have to pay a license per vehicle?
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
