started a thread here for trying to get my door glass out.
I figure if there's anyone in Perth who knows what to do (or able to come down and help out ;)) then I'd really appreciate it...I've just had a bad experience with O'Brien's trying to fix my civic door window 4 times without success so I don't want to pay them to screw up the GTR.
https://www.sau.com.au/forums/topic/258375-r34-gtr-door-glass-removal/
I have an idea......swap my 33Gtr with perfectly working window for your 34 :D
Seriously though if it is anything like other windows I have worked on the bottom of the window will be sitting in a bracket which is attached to two arms that pivot in the centre. The two arms will be attached to the window bracket with a bolt on either end. You will need to remove the plastic film sheet that is between your door trim and door to get acces to the bolts and the window will have to be at the correct height to give you access to the bolts. Once the bolts are removed you should be able to lift the window out without to many dramas. hth
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
    • Neg, the top one is actually for the front. The sizes are 18x10.5 +18 and 18x11 +32.   I measured many times but I'm sure I'll have problems as this is the thread for problems.
    • Just one thing; tapping tapered threads is tricky. Taps are always tapered and you would generally run it as far as you can, but with a tapered thread you have to stop much sooner otherwise the wide part of the taper will run in too far and you will have to thread the sensor in too far too as well (possible that it will never make a good seal) BTW nice wide wheels, I guess the top one is for the back!
