Rb26dett - Oil In Turbo, Intercooler, Spark Plugs !?
Hi guys, here is a chain of events of my problem :
1)Experienced misfiring/engine stalling but no BLUE smoke.
2)Checked plugs to find them all oily.
3)Compression test OK.
4)Removed stock airbox - MAF sensors, Filter, Hoses all oily.
5)Removed hose at Turbo compressor to find a pool of oil contained there (refer to diagram).
6)Removed intercooler pipes - more oil flooded in there.
7)Removed Turbos to check - exhaust side is DRY.
8)Blowby control valve - need to check?
9)Turbo oil supply/return pipelines, hoses - OK, no blockage.
Engine is FULLY a stock setup (including crankcase vent. hoses and PVC etc.) except for the N1 oil pump and Tomei oil restrictor in the Block.Prior to the rebuild, piston #5 and #6 cracked, and I forgot to check whether that could cause a residue of oil in the intercooler, which I did not drain out.First thing came to my mind was that the Turbo SEAL could be defective, but on the other hand, the exhaust wheel is DRY.
Secondly, would the residual oil in the intercooler be re-circulated back to the intake/turbo??
Lastly, I suspected that the oil could leak past the new piston rings but that would be very unlikely because compression test passed and the exhaust ports on the cylinder head are dry.
I am desperately seeking ANY help or useful INFO out there,and I really don't know what else to check or do because I just bought the car. Thanks a million and I would greatly appreciate it...
CLean it all out manualy, im sure its blow by, i had it in mine and was stressed thinging id done a turbo, im guessing its in the rear turbo as well,
Get a catch can bruv and moniter it.. if continues ya blown a seal somewhere take stright to the shop avoid damage..
Check item 8 first. Make sure the thing works properly or you will have the problems you described. A failed blowby control valve will allow oil to get into the turbo compressor housing & leak onto the exhausts after a while. So, does the thing stink of oil when you are waiting at the traffic lights?
But yes if you cracked two pistons & didn't clean anything afterwards you may well have left over oil in the system. However it shouldn't take too long to for it to disappear. Mostly it just leaks out of the bov's.
Thanks for all the valuable advice and suggestions...I disassembled all the piping and cleaned out the entire system...plenty of residue oil in the recirculation tube! After flushing and checking everything mentioned, my engine now runs normally again. I am monitoring for any blowby in the meantime but have not yet fixed the oil catch tank...until really necessary.
I noticed this with my R33.. never thought anything of it, but have recently installed a catch can (blocked PCV and breathers vented to can) I cant say i recall smelling it anymore! Maybe mine was broken too.
I don't understand why people want to block up the blowby control valve when they fit a catch can. If it is done properly you still retain the functionality of the valve.
What if its broken?
I bought the can from RIPS in NZ, and they have alot of huge powered Skylines, i think a 1100HP Street legal R34 too. So i trust their methods :wacko:
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
