hi best mate is just about to bolt everything together and put in back in the car and wondering if i need to be looking for a new motor for him lol. list of things. stock rb25det, gcg high mount manifold, garret turbo .72 front houseing .82 rear houseing (cant remember what the name of the turbo is lol), managed by a haltec e11v2, 600/300/100 front mount intercooler, plazmaman plenum, turbosmart eboost 2. thats all i can think of for now but will it last longer then the dyno tune? cheers stuart
https://www.sau.com.au/forums/topic/258656-stock-rb25detmassiveturbonos/
Need more info to be able to give you a better answer but...
I have seen stock RB25DET's push over 300kw at the wheels, but there are so many variables that you cant account for when extracting big power from an internally stock motor...
Your mate might get a solid run for a while with big power, or he might have to re-build it after it blows a hole in a piston... It depends on how healthy the engine is to start with.
Most of his reliability will come from a really good tune (assuming he is using high quality parts and lubricants aswell).
engine strength is not an issue. its tune quality and how close to the edge of detonation you want to run.
any engine, even a fully built engine with thousands spent will fail under prolonged detonation or preignition.
theres stock internalled engines pushing 300, 400, 500kw reliably
it all comes down to the tune and the quality of your supporting mods to ensure that the measured fuel is delivered and adequate cooling/lubrication is provided.
Yeh, to be on the safe side, I would suggest injectors, fuel reg and probly invest in a good fuel filtration system lol. Judging by the mods he wants a bit of power from it. There is plenty of places to get tunes here in Canberra. I believe ed from Autotech is a Haltech Rep, so probly see him. Or ESP I reckon would know their way around a Haltech and Trojan are Skyline specialists...
has a fuel reg and is getting a new fuel pump (something bigger and better then a gtr one) and some injectors. cheers stu and the tune is going to be done in nsw from someone i have never heard about lol mean while he then is going to take it to a place in sydney.
    • Actually, that's not entirely true. It's also the same motor in the 1st gen Nissan Cube but they're rare as hen's teeth.
    • Yeah it is always worth testing and balancing actuators out of the box, just set the pressure regulator on a compressor very low (eg 5 psi) and increase it slowly to see when they both move.....unfortunately while you may be able to adjust the length of the actuator rod to minimise any difference, the actual pressure they move from is not adjustable so you need a well matched pair. And yes, the VCAM is probably contributing; the earlier in the rev range they come on boost and the slower the revs build (I think your demo was in 5th), the more you notice it.  Driving at WOT through 1st, 2nd, 3rd etc you will probably never hear it as any shuffling starts and is over super quickly
    • oh they were with that motor, you need to remove the engine to change the spark plugs (don't have to, but it does make it easier)
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
