maybe we all should just report everythign to the epa...
loud cars etc too that way we know we are definately doing our bit.
dont get me wrong though but littering is bad and we shouldnt do it.
just its funny to see how somethings when it involves reporting other things ppl look the other way when they are involved.
Edited by tenji`
  • Replies 47
Well I had to learn the hard way.....a couple of years ago I got fined twice for throwing ciggy butts out my car window when I was driving. Now I just use the ashtray to butt out my ciggys now...still ash out of the window....
im not the one who started the thread :(
Yes, And I AM .. and I just got home from a good mate and his family's funeral just a few hours ago! they died in the fires
fires that were deliberatly lit, by someone who didn't care,
my anger starting this thread evolved from someone else who also didn't care, perhalps in a different manner, however it's still just as negligable.
I don't give a f**k if you kill yourself smoking mate, as long as you don't kill others with your lit cigarette butt.
    • I don't care for these at all, but at least the underside looks straight and not rusty. A good basis for a long life. Many cars from Japan have been lifted with forklifts and f**ked almost irrepairably.
    • Yes, but it's not dumb or dodgy. You can build a perfectly good boost controller from a pressure reg, a relief valve (looks same same as a reg if all from Norgren or SMC, for example) and a check valve. I ran one for years. Only superceded with  EBC because I could get one for cheaps and wanted finer control.   THis mod is certainly not a sketchy boost mod, provided the boost is kept below the "spin to death" threshold of the turbos.
    • With ordering the belt, you're doing water pump and the idler and tensioner at the same time too yes?
    • This is just a dumb way of keeping the wastegate closed to make more boost. Undo it and either follow the factory setup or redo it properly. Manual boost controllers just use a spring preload to determine when to close in response to boost pressure so it no longer vents to atmosphere.
    • So for the wide band is a Bosch 4.9 correct for the Link G4+ along with a Can bus? Just get the Link gear or is generic ok too? Eg here: LINK LINK DIGITAL WIDEBAND CAN MODULE WITH BOSCH 4.9 SENSOR : KYP Performance House
