hi guys these were on my 32gtr
specs are
19 inch by 10.5 wide f&r
+20 offset
looks fat and tough. only a little scratch which i got quoted for $200 to fix. all 4 rims have brand new rubber which cost me over $1k.these are located in sydney/west also comes with rays wheel nuts and volk centre cap.
asking price $3500
Edited by xxx200
https://www.sau.com.au/forums/topic/258747-volk-gt-c-face2/
According the the Rays website, there is no +20 offset...
http://www.rayswheels.co.jp/cgi-bin/cgi2/s...modelName=GTC_2
yea, i talked to my friend, he didnt notice there are +20 before.. custom?? picsss!!
https://www.sau.com.au/forums/topic/258747-volk-gt-c-face2/#findComment-4449630
Err... you can order Rays wheels in any offset you want when the wheels are 2 piece.
I'd suggest you check your sources for that info because that is not entirely true. Some models of Rays rims you can get any offset to the mm, some you cannot.
https://www.sau.com.au/forums/topic/258747-volk-gt-c-face2/#findComment-4450259
Check my sources? lol ok. Eugene just because you sell a lot of Rays wheels, does not make you an authoritative source either. GTC's you can order a custom offset. I left the word "some" out of my post, but in fact most Rays 2-piece wheels can be ordered in custom offsets.
https://www.sau.com.au/forums/topic/258747-volk-gt-c-face2/#findComment-4450453
Ok fair enough, now you got me curious as last time I asked about custom offsets, they told me no.
So I will check with them again on Monday.
https://www.sau.com.au/forums/topic/258747-volk-gt-c-face2/#findComment-4450916
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
