Hey was nice to meet you guys and put some faces to the names (which I promptly forgot :D
Track day tomorrow, I'm excitement!
how can you forget me man lol
track day sounds real good....would be interesting to see what times you pull
  • Replies 881
names are meant to be forgotten. :cool:
dont forget to get 'your people' to gimme a buzz on monday. :P
Can't forget you scandy man, your name was eduardo, right?
and krishy you were Christianos? the guys with 2 sausages right?
Yeah we will buzz ya on Monday and see what we can do for ya ;)
Edited by medman2damax
I picked up a whole bunch of mags as they were there and we were the last ones to leave....you can get them on monday luke
with the pages stuck together...lol good thing you didnt leave your girlfriend or krishy would have picked em up for the weekend too..lol
car porn hey krishy
car porn hey krishy
Well troy someone's gota pick up the pieces.....
Your car stereo test results
Your RTA/SPL export Krishy, other peoples from BP will be later, also the spectrum analyzer export to follow
Thanks for that troy...i think you will need to explain what they all mean mate
keen to get it sorted out and hopefully get a better sound....
Edited by Krishy
I assume everyone will be locking their cars away tonight, since there will be cops everywhere?
id say so.... lol my muffler snapped off coming home last night! -1 for drone spec! i mighttt hit up villes tonight but dno if im keen for a drive after as the cop situation will be crazy!
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
