  • Replies 881
the cure for the rick roll is wait til the browser stops moving, then close the tab, hold down enter until it runs through the lyrics, then the tab will close.
hahaha love Firefox.........do what Damo said and firefox will ask you "Do you want to navigate away from this page".....all you gota do is say f**k YES and Rick is gone
I plan to be there ... but I am selling a house and have a few more items to do around the property. Open inspection is the following day, so I don't have much time. I'm getting a few jobs done after work tonight, so I'll know by tonight if I'll be in attendance.
Might also take part of the day off tomorrow ... just to put the missus's mind at rest that all wil be done and dusted.
Ruby, I rolled up to BP last Friday night to give you my club membership form but there was only a blue Stagea and a R32 there... both of which I didn't recognise from on these forums.
Ah, sorry mate. I was stuck with the 10yo lad. Got out to Vilis for a bit, but he was tired and grumpy by the time we left Vilis. I'll be out this Friday night at the BP :/
that would be Chad (DSTROY) in the 32 and Lex in the blue stag
if its the same 32 i saw it wasnt chad
Possibly Dion then? Nathan?
Talbo, I'll be out this Friday if you want to get the form to me then :rofl:
can someone bring a membership form for me please???
Sure will :D
Edited by RubyRS4
Talbo, I'll be out this Friday if you want to get the form to me then :D
No problem, I think I should be good to come past tomorrow. :D
It wasn't chad's 32, i've seen his and it obviously has the custom # plate. The blue Stag had a custom plate however.
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
