found out two things from last night...my car felt wierd through the steering....because i split my high pressure line.....the next one is the reason my car was fumy was unforunately found out today....im now in the hunt for a new turbo as mine has shat itself...do good things come from monsta???
  • Replies 881
I hear not, if you don't keep good oil running thru them.
I've got a "no name" turbo (read: big f**ker) in my shed I never fitted. New, never used, if you're interested. Cheaper than cheap :( Is oil cooled only.
Edited by RubyRS4
What time did you guys leave BP last night, I got there around 9:40ish and no one was there...
Blame Pete for that one :( We were all discussing moving on to BP, then Pete turned up. We figured it was best not to abandon a Mod. :D Didn't get to BP until like 10.00-10.15pm?
Sorry dude.
So I finally made an appearance at Villis, was so good to finally meet people!
Cheers for making me feel welcome :P
Thanks for joining us and smuggling in your Mother :P
[how many people will understand that comment?] :)
Oh, and thanks for the membership form. Welcome #22. Next year you'll want 23? :P
Edited by RubyRS4
Cheers for making me feel welcome :)
it was good to finally meet you in person as well Penny....i will email you once i get into work tomorrow....
Thanks for joining us and smuggling in your Mother :laugh:
[how many people will understand that comment?] :ninja:
Oh, and thanks for the membership form. Welcome #22. Next year you'll want 23? :kiss:
hahahah not a lot ruby.....watch out you might get e-bashed by the keyboard warriors hehehehe
i think Penny also started the craze for mother....every was getting theirs out :)
i only just got that..never saw her do it but its clicked.. been out of school for a year and ive already lost my brains haha
i think Penny also started the craze for mother....every was getting theirs out :laugh:
I had my Mother before she had hers :):kiss: (cool ... double meaning!) :ninja:
dont want to burst your bubble rubes....but im #22....penny got hers before me
D'oh! :)
your avatar disturbs me roo lol!
Disturbs me too :woot: ... make the God of Pelvis Thrusting stop!
D'oh! :)
doesnt disturb me. does that make me weird(er)?
no it doesnt make you weird(er).....just means you like the pelvis thrust :wub:
    • Maybe it's time for a M3 F80 LCI, and leave it stock.  Drive it to a shop, sip on your latte with nutmeg whilst it gets serviced and on the way home swing by and grab some chai mix for the evening.
    • Great work! Thanks for documenting the process.
    • How would you even adjust the clutch if the pedal already has the correct free play? The operating cylinder has no adjustment in mounting position or rod length. On pull style clutches there is also no ability to adjust the bearing carrier. Push type I can see how adjusting the carrier height makes it all work.   If this is the twin plate clutch did you verify that your friction disks were oriented correctly? It's not mentioned in the directions at all you just have to notice that one side the friction disks have a part number on the hub fingers and a subtle coning to those fingers. Another thing that I noticed was if you put the friction disks in backwards the pressure plate fingers will not be even and flat when the clutch is installed.
    • yeah, mechanically, it is probably do-able, off the top of my head, there would be the transfer case, which I believe will bolt up to the rear of the RWD transmission, the shorter rear tail shaft. A front drive shaft, front diff, engine upper sump, front drive shafts, front hubs and front AWD struts (they are shaped around the front drive shafts), LCAs (at the very least from the front suspension) oil cooler.  You might want the rear diff from an AWD too, so you can be certain the front and rear diff rations are identical.  Who knows what brackets and mounts you might need.  So a whole doner car might be the best option if you need to maintain RHD. Then actually making it work, that would be a whole different story.
