I can't beleive it. Alloy guard is dented, I want a brand new one from Japan sprayed. Thats what I'll be telling the painter I take it to, No bog, No nothing but the best...
The womans insurance company is going to have her
  • Replies 881
My car got reversed into today... I aint driving the fpos till the front quater is fixed.
Cant beleive it... Shattered. Atleast the bitch that reversed into me has insurance.
awww man, sorry to hear, stupid lady should watch where she was reversing!
Ah shit Weez, Make damn sure its fixed as good as new!
Not bailing her out, but I cant say I like the idea of the alloy guards/bonnet thing, way to soft material for a panel on a street driven car IMO. I have a GTR alloy bonnet on my 32 and the bloody thing has a few imprints of people knuckles when shutting it.
Hence why I 'drop' it and not push it down when you close the bonnet...
The car is fine to be street driven any car that gets reversed into is going to buttsecks... Only difference mine is gonna cost the b!tch alot more...
Brand new 1/4 from Japan or a MINT 2nd hand one resprayed or ban!
    • It's almost certainly a reluctor generating an "AC" waveform. No, ECUs don't generally read those - they're usually set up for PWM square wave 0-5v stuff.
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
