  • Replies 881
I have this feeling my car is going to end up like Scandy's.
SAU:SA #17
Car(s): R32. Hardparked.
Real Name: Dion
Trader Rating : 1
Need to do Turbo, FMIC, Coilovers, A/C compressor, Seats and Steering Wheel. I know its not that much really but we're talking about me here. Oh and also RB26 Injectors - I believe it already has an upgraded pump, but if not, that too.
i have a case of CC's n dry....very nice taste
So who is going to help me now????
cc dry... you just became my new (temporary) best friend.
<snip>
lol. ill give you both a hand with all that.
yay i has a temp new friend :P
I will go and see andrew at am on friday and get him to make the intake and dump pipe and that way once they are made we can start on it straight away.....roughly how long will it take Dave to slap it all in????
dunno. depends how many cc dry's ive had and how awkward the rb is to work on. should be about a couple days (i like leaving a margin of error). now takes me about 90 minutes to do a turbo on the sr.
question, rb uses locking tabs on the turbo studs, yeah? if so, f**k them off and buy some prevailing torque nuts, theyre a slight pain in the ass, but i doubt they'll f**k out as quick as the lock tabs.
Edited by scandyflick
lol i have no idea what you speak off there Dave.....
lol. find out when we pull your turbo off i spose. but add maybe $10 for half a dozen prevailing torque nuts.
when you wanna do it?
When andrew has finished making the intake and dump pipe....will take the turbo to him on friday
CC is my fav. Basically sleep with the stuff.
However just got nice little connection atm. $80 dollar Cognac bottles for $30. very very nice stuff.
oh, so this thread is talk about villis?
i may be there for a bit, meant to be getting the bitch muddy again, but got a lot on this weekend so dont know if thats wise
save the mudding for saturday, ive got the weekend off and will be in need of cheap luls. :)
Ok my bad >_< I fly in to Adelaide at 10:30pm....Was looking at the wrong details LOL
Doubt you guys will be at villies still that late...
around that time we usually are at BP lol...but since we aint going there no more who knows where we will be
Oh you guys still do that.....
I used to hang at Shell LOL ...That was a longggggggggggg time ago now tho :down:
Well I will be at the public meeting if all else fails! >_<
save the mudding for saturday, ive got the weekend off and will be in need of cheap luls. :rolleyes:
saturday night john is busy, and apparently ive gotta make an appearance at drifts if i want some mudflaps LOL
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
