go the pies richmond did well for three quarters though when they can play four quarters they will be a hassle to beat....did anyone see cousins throw up i was drinking at the time brought back memories made me stop drinking
https://www.sau.com.au/forums/topic/258857-footy-season/#findComment-4448707
Didn't seem to faze him too much. Must be used to having big nights or something :wacko:
https://www.sau.com.au/forums/topic/258857-footy-season/#findComment-4448732
Yeah could be that he was pushed pretty hard, I didn't see the match, did he cop a big hit? I used to see a lot of guys hurl during gradings at Karate.
First quarter he got his head taken out by a tackle. thats all i seen. didnt seem to bad but must of hurt him
https://www.sau.com.au/forums/topic/258857-footy-season/#findComment-4448741
no Rusling, Medhurst, Rocca in our forward looks very promising indeed
I know fingers crossed.
Massive fan of Harry O and Shannon Cox is coming along nicely!
And how good is DIDAK?!?!?! He is cleary Peter Daicos' love child.
https://www.sau.com.au/forums/topic/258857-footy-season/#findComment-4448744
My standouts are Didak, Johnson is coming good. Leon davis brilliant and heath shaw is proving he can play.
Mate alot of potential there we just got to be tight all year and not loose stupid games
https://www.sau.com.au/forums/topic/258857-footy-season/#findComment-4448749
Richmond not with a full squad kept with Collingwood for 3 quarters, who where pretty much at full strength bar 2 players.
Yep Collingwood are going to be great guns this year!
GO CATS!
Richmond where not even close. Not sure if you watched the game but scoreboard didnt do the pies justice. they smashed them all over the ground
https://www.sau.com.au/forums/topic/258857-footy-season/#findComment-4448756
    • How would you even adjust the clutch if the pedal already has the correct free play? The operating cylinder has no adjustment in mounting position or rod length. On pull style clutches there is also no ability to adjust the bearing carrier. Push type I can see how adjusting the carrier height makes it all work.   If this is the twin plate clutch did you verify that your friction disks were oriented correctly? It's not mentioned in the directions at all you just have to notice that one side the friction disks have a part number on the hub fingers and a subtle coning to those fingers. Another thing that I noticed was if you put the friction disks in backwards the pressure plate fingers will not be even and flat when the clutch is installed.
    • yeah, mechanically, it is probably do-able, off the top of my head, there would be the transfer case, which I believe will bolt up to the rear of the RWD transmission, the shorter rear tail shaft. A front drive shaft, front diff, engine upper sump, front drive shafts, front hubs and front AWD struts (they are shaped around the front drive shafts), LCAs (at the very least from the front suspension) oil cooler.  You might want the rear diff from an AWD too, so you can be certain the front and rear diff rations are identical.  Who knows what brackets and mounts you might need.  So a whole doner car might be the best option if you need to maintain RHD. Then actually making it work, that would be a whole different story.
    • Take the fall as a warning sign for future endeavours  Stay safe mate
    • hi mate, HKS cooler piping still available by any chance?
