Yesterday spent another few hours on the dyno,
attached are the sheets, dynos.pdf
the power has increased by 50 rwhp. Still have poncam gears set on 0,0, so next time, the hours will be spent dialing in the cams which should net some quicker response and maybe higher end
As you can see, I am still having a few boost control issues with my EVC6 in that it holds approx 18 pound for about 1000 rpm and then tapers off slowly no matter what we do.
If you have a look at my run-in tune graph, almost exact same spot in the revs we had the same issue Dyno1.pdf IGNORE THE EXTENDED HAND DRAWN TOP BOOST LINE, I DREW THAT IN TRYING TO ASK THE TUNER WHY IT WILL NOT STAY THERE, the true top boost line holds and then dips at at just before the 152km mark drops off
Also what is interesting is that setting a, is set at 14.3, boost will hit about 14.7 and hold steady on the road.
Setting b is set at 17 psi and will hit and hold at about 18.9psi on the road, so something is clearly amiss but not sure what, any ideas?
I think I will swap out for a pneumatic controller to see if we can get some consistent control to see if it is the EVC6 or something else but would love to hear from anyone else that may have had the same issues.
R31Nismoid, I owe you a huge apology, currently on 321RWKW on a very safe tune and only a smidge over 15 psi at the power mark with cams not dialed in yet so your ongoing advice of 300 to 330rwkw from GTSS's is spot on and I think once I resolve my boost issues (ie get it to hold a constant 17/18psi) and have the cams dialed in, I will be able to safely acheive at least the 330rwkws.
I tell you what though, the extra 50rwhp makes a HUGEEEEE difference
Edited by R33GTRKid
https://www.sau.com.au/forums/topic/258861-new-dyno-results/
still having some boost control issues.
As you can see, boost holds 18 pound for about 100 rpm and then tapers off slowly no matter what we do. I have an EVC6.
for what it is worth, I have the same problem with the HKS EVC 6. I lose ~2.5psi and not just at the end, it is a gradual decay.
Have you tried one of the FUN modes - the one where you can set boost map vs RPM?
hey mate, Ant Scali of X-speed (licensed HKS tuner/dealer) is tuning it, so i would expect him to have done all he can to sort it. Next time it goes in (read I have some more cash) he will plumb in a t-piece to see if that holds boost and if it is, we will do a full check on their install of the controller and if all ok, look to replace the unit on warranty
Congrats on the extra power, and good show manning up with the news etc - it all helps clear things up and make them more useful for future. Might be worth bumping the thread the discussion was had in and clarifying that for people using the search function in future :wacko:
Ash when are you hitting full boost?
Simon that looks real laggy full boost by 4600 is that normal? What are the twin gtss supposed to do? What actuator you got on there?
Power looks nice, better update you power register in the wa section, your definetly up there now.
Patty,
Yeah it may be alittle late but the cams are set on 0,0 so once they are dialed in it will bring that back probably closer to the 4,000 rpm mark and then it will be super responsive.
Ant reckons it is making the power very easy and that 431rwhp is only at 15 psi too given tapering off of boost issue.
Once we get that sorted and can run a solid 17/18 psi through, we should see a comfortable 450rwhp and that will be where I stop to keep it safe on the bottom end. Ill have to go back to plex next week to see if I can crack into the 11's, If i cant then I may hang up the keys hehe.
I have the heavy duty HKS actuators that came with the GTSS kit
That dyno graph is eerily reminiscent of mine. Just that I used a -5 Garrett & a different tuner. The numbers are within a few rwhp all the way up the graph.
A couple of things:
1> Why do you want to get rid of the extra boost about 5000rpm?
2> I recently checked the voltage from my Z32 AFM's from the Power FC using the peak/hold function. Spat out a few milli volts below 4.0Volts for a supposed 435 rwhp. I would be curious to see what number your give (If you have AFM's that is). I cross checked it with the Nismo AFM cruve to use the mass flow & hence calculate the engine output. Worked out spot on.
djr81,
we have no idea why the extra boost is disappearing at about 5,000 kms odd, it seems to a boost controller issue that we cannot fix at the moment so looks like I am going to have it replaced on warranty to see if it really is the problem.
I do not have AFM's mate, as X-speed recommended D'jetro.
Had dramas with the earlier units, one thing you can try is to put a restrictor into the signal supply line to the solonoid/actuators. It may be a case where the solonoid cannot purge off enough signal to allow the actuator to remain a little more closed (higher boost).
D-Jetro? Is it strictly a track car? For 330kw? Even stock afms would cope with that.
    • Haha, i kow right? Could have bought so many cars for the same amount of money (or less) but driving Unicorn gives you at least +1mln to style 😅. Like wise man said "life's to short to drink cheap wine and drive boring cars" 😉
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
