Hey guys,
I still have a bunch of stuff to get rid of. Have redone my list of parts and deleted all sold items to make it easier to read. Also added some new stuff. Located in Sydney. Pickup or willing to post most things anywhere at buyers expense.
More stuff to come. If you have any questions or for pics PM me.
Cheers.
- Rb20 rocker covers series 1 (painted black) $90
- Fibreglass GTR copy front bar - Removed from 92 GTST (Has crack and minor damage...also bottom lip chopped off) $150
- R32 GTR Series 1 dash modified to have gtst tacho w/clock - Fits all R32's with slight wiring modification (Series 1 should be straight fit for GTR/GTST) Also good for parts $50
- Rb20 crossover pipe w/bov mount $10
- Bottom half of Rb20 plenum $20
- Rb20 series 2 timing cover $5
- Rb20 PCV valve $10
- Top half Rb20 plenum (has been machined on mounting section so only good for making into custom plenum) $5
- Rb20 exhaust manifold $10
- Sr20 fuel regulator $20
- New Durapro intake side metal gasket kit w/dump pipe gasket thrown in - Suit RB25 Neo engine $100
- VL oil pressure switch $20
- Clutch fork from rb20 box $5
- Rb20 alternator $90
- Rb20 flywheel $50
- New VL exhaust manifold gasket (has small cut between No.1 and No.2 exhaust ports but will not affect sealing) $20
- Red neon light roughly 30cm long $10
- VL Turbo manual ecu (was reco'd in 1999...cant remember if chipped or not) $100
- VL afm with airbox top half $30
- VL clutch slave cylinder $10
- VL clutch master cylinder (has not been used for a long time so may need new seals) $40
- VL gearknob $30
- VL commodore/calais owners handbook and product information books in a sundells holden folder (owners handbook good condition/product info book glue is coming adrift at spine) $30
- R32 GTR/GTST passenger side taillight in black $50
- VL fuel pump $30
- VL auto ecus X 3 $30ea
- Rb20 starter motor $50
- Hornet scoop ( has had fibreglass repair and resprayed white ) $100
- VL afm $20
- VL dizzy complete $50
- VL alternator $50
- VL coils X 2 $10ea
- VL fuel regulator $30
- VL coolant temp sensor $20
- VL tps $20
- VL power transistor $10
- Damaged Black 1981 KE55 Corolla Sedan (No rego,no plates...130,000km, repairable damage) $1000ono
- NSW number plates GO55GO $Offers
- Woodgrain steering wheel w/chrome centre (cracks in wood at joins of spokes) $30
- Fibreglass panels - suit KE55 corolla - brand new L+R front guards, bonnet and bootlid (all painted black) $500
- Set of KE55 tailights (passenger side has small hole in lens) $70
- KE55 diff - drum to drum (broken sun gear shaft...suit locker or repair) $100
- Set of 4 toyota sprinter AE86 13 inch 4X114.3 wheels (tyres not good) $300
- Set of 5 ROH 15 inch 4X114.3 wheels - tyres are good on most of the wheels $120
- KE55 rear "corolla" centre garnish $20
https://www.sau.com.au/forums/topic/258958-r32-vl-corolla-stuff-for-sale/
Update:
- Rb20 flywheel $50
- VL gearknob $30
- VL fuel pump $30
- VL afm $20
- VL alternator $50
- VL tps $20
- Wrecking Black 1981 KE55 Corolla Sedan (pm me for prices on parts)
- NSW number plates GO55GO SOLD
- MX7 VL turbo 5 speed gearbox (has a light knock but works well...strong box...suit rb engines) $900
Edited by nIsMo86
  • 4 weeks later...
Update:
- Fibreglass GTR copy front bar - Removed from 92 GTST (Has crack and minor damage...also bottom lip chopped off) $100
- R32 GTR Series 1 dash modified to have gtst tacho w/clock - Fits all R32's with slight wiring modification - Also good for parts $50
- Sr20 fuel regulator $20 SOLD
- Rb20 flywheel $50
- VL clutch master cylinder (has not been used for a long time so may need new seals) $20
- VL gearknob $30
- VL fuel pump $30
- Rb30 starter motor $50
- VL afm $20
- VL alternator $50 SOLD
- VL tps $20
- Wrecking Black 1981 KE55 Corolla Sedan (PM me for prices on parts)
  • 3 weeks later...
Update:
- Rb20 rocker covers series 1 silvertop (painted black) $90
- Rb20 flywheel $50
- VL gearknob $30
- VL fuel pump $30
- VL afm $20
- VL tps $20
- Wrecking Black 1981 KE55 Corolla Sedan SOLD
- Woodgrain steering wheel w/chrome centre (cracks in wood at joins of spokes) $30 SOLD
- Set of KE55 tailights (passenger side has small hole in lens) $70 SOLD
- KE55 diff - drum to drum (broken sun gear shaft...suit locker or repair) $50
- KE55 rear "corolla" centre garnish $20 SOLD
  • 2 months later...
Hey mate, really interested in the corolla panels, can you please either call me or PM me your number, im unable to PM as just joined. Is the bonnet a KE30 or KE55 shape? KE55 has a larger lip on the front just in case you were not sure, also are they good quality moulds or sprint car stuff?
Let me know asap, im from Wollongong so can pick up if needed.
Jason
0422 447 545
  • 4 months later...
  • 3 weeks later...
  • 3 weeks later...
  • 2 months later...
    • Thanks mate, couldn't find in VIC, ended up ordering one from NSW, getting rwc to get new plates and registration done.
    • Before all the EFR fan boys come in, have a look at: https://www.garrettmotion.com/racing-and-performance/performance-catalog/turbo/g-series-ii-g30-825-58mm/ It also comes in a T4 1.06 divided housing. I would dare say if you want response & also decent power, this thing would chop.   AND apologies, just re-read your post, you've already bought the turbo... whatever you do, make sure you stick with divided housing and proper twin scroll manifold.
    • People have got to stop doing that. ShatGPT is not a search engine. It is a hallucination factory.   I also would recommend the 1.05. The .83 will "work" for you , in that it will be more responsive, but I think you'll find that it won't be anywhere near as good running it out to 8000rpm as the big housing will be.
    • Decided for the first time ever I would tow my car TO the track day on the same working theory as bringing tools and spares "if I have it I wont need it, but if I leave it behind i will 100% need it" all setup and ready to go out and try these A050 for the first time First session showed I needed to stiffen up the dampers a touch but still managed a few 1:21's without much effort. things were looking good. Came in a dropped the tyres down  to 26/28 as they had gotten to 35/33C from 22C cold The first lap of session two I managed to drop into 1:20's. Then in the second lap into the second session. Coming into T3 and I suddenly lost brake pedal followed by some huge rear end vibrations and scraping sounds. Got it back into the pits after session ended and found this. in the attached video, all of the wobble is in the hub its self, wheel is mint, and bearing feels tight. lKXLqpd - Imgur.mp4   Deciding it was a bent spindle I tried to find bearing/hub assembly locally but was unsuccessful so it was loaded back onto the trailer i luckily brought it on to drag it back home
    • 1.05 you’ve gotta let it breath
