  • Replies 126
yeah i understand the engine rotates clockwize but wouldnt turning the centre of the pulley clockwize advance the cam timing not retard it????
im sure the centre of the cam goes counterclockwise to retard
Damn, your right. Sorry about that.
To delay the cam (the cam is fixed to the center of the cam gear) the centre of the cam gear should be turned counter clockwise !
I was thinking of it the other way around :D
My bad.....
J
Ok I've got my 2 degrees dialed in. I've thought about it and I have to agree with the consensus of anti-clockwise.
Now I don't want this to move, ever. So I'm thinking I will put some loctite on the nuts or something.
Sorry to keep replying to this thread :D But I'd never seen a picture of an Apexi cam wheel before mine arrived this morning. I thought some of you might be interested so I took 2 pics and attached them here.
When I was looking at buying one I found Apexi to be the cheapest, and because of that it made me wary. To be honest if the brand wasn't Apexi I would have gone for a more expensive one, it was just that I trusted the name and so I decided to go for it. After looking at it and feeling how solid it is and how precise the machining is, I'd say it's as good as any other in the quality stakes.
There are no doubt lighter/stronger ones available, but at a higher price. I'm happy with my choice.
11261 yen plus 2100 yen delivery = AU$175 at the exchange rate on the day (a few weeks ago).
The HKS one was the next one up on the price list at around 11800 yen I think.
Jay, does this mean you've adjusted yours in the wrong direction? :) Or you just forgot which way you did it until now.
I confused the crap out of myself !! LOL
I adjusted it correctly, then yesterday my brain got scrambled and I explained it wrong !
Thank god it's Friday....
J
Ok now I'm just depressed. The hardest thing so far is getting the wheel back on. How do yo do it? I tried putting the original one on but it's still bloody impossible. What can I use to lever it on and where do I lever it? There just doesn't seem to be any points where I can lever it from.
The cam seems pretty well fixed in place, if I can't rotate the crank with a socket (since I don't have a 27mm one) can I move the cam slightly? I've already marked where it was when I pulled the wheel off so I've got a reference point.
No rush in response, I'm going to leave it for the day. I need a break!
JimX - if you can't rotate the crank, then rotate the cam a little - and I mean just a little.
You'll need to rotate the cam counter clockwise.
The other option is to set the cam gear to zero, put it on, then adjust it on the car. Not my prefered way of doing it, but I suppose that's the way they dyno tune them (eg. adjust them while their on the car.)
J
Well, the problem is I can't even get the original one back on :( The belt is just too tight. Can I somehow loosen the tensioner or something? Or just lever the wheel on somehow.
Hmm, did you clamp off the belt to the inlet cam wheel??
I was thinking before, you might be able to get the crank to move back a little by just grabbing the air con and power steering belts and yanking them backward. Not sure if it'll work, but it's worth a try. It might give you just enough movement to get it on.
When you've been trying to get the wheel back on, how close is the dowl to the dowl hole on the cam wheel? Can you see where it's out?
It's strange cause I had no problems with the tension of the belt, the only problem I had (with both cars) is that the dowl wasn't lining up with the dowl hole on the cam wheel - hence why I said a slight rotation of the crank let me get the cam wheel on.
I can't think of anyway of levering it back on. But maybe if you slightly rotate the inlet cam wheel which will pull the belt tighter on the tensioner which in turn will give a little bit of slack on the exhaust side.
Then when the exhaust cam is back on, just make sure the marks still line up and then the tensioner will move the belt back to where it was before (cause the belt is toothed).
Give that a try and see how you go.
J
    • The rain is the best time to push to the edge of the grip limit. Water lubrication reduces the consumption of rubber without reducing the fun. I take pleasure in driving around the outside of numpties in Audis, WRXs, BRZs, etc, because they get all worried in the wet. They warm up faster than the engine oil does.
    • When they're dead cold, and in the wet, they're not very fun. RE003 are alright, they do harden very quickly and turn into literally $50 Pace tyres.
    • Yeah, I thought that Reedy's video was quite good because he compared old and new (as in, well used and quite new) AD09s, with what is generally considered to be the fast Yokohama in this category (ie, sporty road/track tyres) and a tyre that people might be able to use to extend the comparo out into the space of more expensive European tyres, being the Cup 2. No-one would ever agree that the Cup 2 is a poor tyre - many would suggest that it is close to the very top of the category. And, for them all to come out so close to each other, and for the cheaper tyre in the test to do so well against the others, in some cases being even faster, shows that (good, non-linglong) tyres are reaching a plateau in terms of how good they can get, and they're all sitting on that same plateau. Anyway, on the AD08R, AD09, RS4 that I've had on the car in recent years, I've never had a problem in the cold and wet. SA gets down to 0-10°C in winter. Not so often, but it was only 4°C when I got in the car this morning. Once the tyres are warm (ie, after about 2km), you can start to lay into them. I've never aquaplaned or suffered serious off-corner understeer or anything like that in the wet, that I would not have expected to happen with a more normal tyre. I had some RE003s, and they were shit in the dry, shit in the wet, shit everywhere. I would rate the RS4 and AD0x as being more trustworthy in the wet, once the rubber is warm. Bridgestone should be ashamed of the RE003.
    • This is why I gave the disclaimer about how I drive in the wet which I feel is pretty important. I have heard people think RS4's are horrible in the rain, but I have this feeling they must be driving (or attempting to drive) anywhere close to the grip limit. I legitimately drive at the speed limit/below speed the limit 100% of the time in the rain. More than happy to just commute along at 50kmh behind a train of cars in 5th gear etc. I do agree with you with regards to the temp and the 'quality' of the tyre Dose. Most UHP tyres aren't even up to temperature on the road anyway, even when going mad initial D canyon carving. It would be interesting to see a not-up-to-temp UHP tyre compared against a mere... normal...HP tyre at these temperatures. I don't think you're (or me in this case) is actually picking up grip with an RS4/AD09 on the road relative to something like a RE003 because the RS4/AD09 is not up to temp and the RE003 is closer to it's optimal operating window.
    • Either the bearing has been installed backwards OR the gearbox input shaft bearing is loosey goosey.   When in doubt, just put in a Samsonas in.
