I have one of those timing lights that shows up double what it really is. ie, 30 degrees when it's really 15. How would I go about setting it to anything higher than that? 30 is the highest marking on the crank.
  • Replies 126
Thanks SydneyKid - that's exactly what info I was after. I'll be having a play with the timing next Wed when the car is having a play on the dyno.
Lukits01 - turning the CAS anti-clockwise will advance the timing. Is this right everyone? Or have I stuffed up the direction again... LOL
cannot really add much to what has already been said, but.........
The easy way to turn the engine over to exact TDC, or anywhere else, is to put it into fifth gear and roll the whole car backwards or forwards. Slop in the drivetrain allows you to bounce the engine. Try it, you will see what I mean. When it's there, put on the handbrake. Easy. If you have an auto, bad luck.
Another thing, fair enough you can retard it four degrees, but how do you know that the starting position was correct ? Also belt tension and belt stretch just by itself can shift it nearly that far.
Think about it, if the belt has stretched, and you tension in the belt a bit on the slack side, both cams retard by however much the belt has stretched. only a couple of mm is actually a fair way. One whole turn being 720 degrees.
To do it properly you need a dial indicator and degree wheel, and find out exactly where each cam is, and where it should be. It's a lot of work, and a pain in the arse, but its the only way to know for sure.
Hi Warpspeed I am confused, the standard RB pulleys have marks which you line up for TDC of the camshafts. The crank also has a mark on the pulley for TDC. If these three marks all line up then the crank is at TDC, the inlet camshaft is at TDC and the exhaust camshaft is also at TDC. If the adjustable pulley is marked correctly then you can lock the camshafts at TDC and the adjustable pulleys should just slip on, when they are on zero correction. If the adjustable pulleys have marks for degrees and they are accurate, then you know the exhaust camshaft is 4 degrees retarded when it is on the 4 degree mark. No guesswork required.
Back in the old days we use to have to degree in a camshaft because the grinding was not as precise as it is now. I haven't found a camshaft in a Japanese DOHC multi valve engine that is not marked precisely for TDC for the last 10 years or so. Since we tune the camshaft position on the dyno it doesn't matter anyway, we adjust the pulleys to the point that makes the power curve the way we want it. So I don't care whether it is 4 degrees or 10 degrees on the pulley marks, it is where I want it that's all that matters.
Hope that helps
Yes I agree, the cams themselves are pretty precise, and probably so are the gears and crank key. The problem is only with the belt.
If the belt is slightly longer on the tight side because it has stretched, and you take up the slack with the adjuster, then both cam pulleys will have rotated very slightly anticlockwise with respect to the crank. As far as the timing marks go, you can only really fit the belt one whole tooth out, and the error is pretty obvious. But what if it is just a fraction of a tooth out ? The timing marks will still look o/k. Would you actually notice 2mm ?
Not sure, but I think the cam pulleys have 48 teeth. that is 720/48= 15 degrees per tooth. 2mm of belt stretch (with an 8mm pitch belt) is one quarter tooth, or 3.75 degrees.
2mm belt stretch is not a lot between crank and exhaust cam over almost half the whole belt length, on a high mileage belt. Sure, the belt will be a bit loose, but tightening it back up could shift both cams by nearly 4 degrees.
If you really heave on the adjuster, you can actually see the damned things move ! I kid you not.
I am probably being a bit of an old woman about this, but people here are going to a fair bit of trouble and expense to do the 4 degree exhaust cam tweak, expecting to pick up measurable power. If the cams are maybe four (?) degrees out to begin with, the results may not always be quite as expected.
  • 1 month later...
Hey guys
my cam gears are finally here and Im about to try and install them, probably this weekend
been looking at the engine bay
was wondering how do you take off the Cam gear covers off?
how many bolts are there and roughly where are they located?
hahah i lost one nut from the cam cover belt. It just disappered :) And the worst thing was that it was the last nut i was puttin back on. Then trying to find the thing took longer then what it took to install the cam gear. It was really easy, thanks to all the help from everyone. Its gettin tuned tomorrow.
thanks guys cam gears installed and working
awesome stuff
hit full boost by 1000 RPM ahhaha
just a note there are actually 8 bolts on the cam cover
hey when setting the base timing to 15 Deg is it on the 3rd white line after the first orange line? and what RPM should the timing be done at?
My Trust Ex Cam Gear arrived yesterday from Nengun (13,000yen + Shipping, took 2 business days to arrive). I just re-read over this entire thread to see if i'd be able to do it myself and it was an absolutely comedy haha.
I was going to ring UniGroup this arvo and ask them to do it (I want a before/after Dyno run) but $160 is pretty rich, i'd happily pay $100 for it if its only a 30min job but $160 makes a cheap mod into an expensive mod.
Hey JimX... :bananaman
Hi JAY95R33/ JIMX,
Did retarding the ex timing make the car feel any different?
Do you mean "did retarding the exhaust cam gear make......."
Then yes, as said earlier on in this thread, I found retarding the exhuast cam gear by 1.5 degrees (3 degrees crank angle) gave me an improved mid range.
Cheers
Jayson
    • Welcome to my 2004 Toyota Mark ii IR-V Fortuna (series 2) With a 1JZ-GTE powerplant under the bonnet (hood) it'll give me plenty of scope for power upgrades. For those who aren't familiar with imports, the 1JZ-GTE is a 2.5L 6 cylinder VVTi engine with a single turbocharger. This has the factory R154 5 speed gearbox, along with a aftermarket 2 way LSD differential (brand unknown). Under the arches are a set of CST Zero 1 alloys, 18x9 +30 225/40 up front and 18x9.5 +15 265/35 on the rear. The car was quite low in Japan and there's evidence of the wheels catching the rolled arches/fenders. The tyre's aren't great so I'm in two minds whether to replace both or just the tyres and put up with the wider wheels on the rear. The car still uses stock brakes with the addition of some braided hoses. The exterior is stock with the exception of a BN Sports front bumper and a replacement Fortuna grill  Moving to the interior, the steering wheel has been replaced with a dished MOMO steering wheel (which will get swapped for my Momo Tuner for the time being) Defi Link Gauges are mounted above the climate controls and on the A pillar, the Oil Temp,Oil Pressure,Water Temp and Boost gauges should help with spirited and track driving  The stock seats have been replaced with some retrimmed Recaro bucket seats. Being a larger build these are a little snug, unfortunately the orange isn't for me so I'll look into replacing these down the line. Other modifications include a twin plate clutch, Blitz intercooler, Evolve alloy radiator, a stainless exhaust with decat, HKS EVC-S boost controller and coil overs
    • Apologies for the long read My R34 GTT was up for sale at the beginning of spring due to a few repairs creeping up. The strut tops needed replacing, roof and bonnet (hood) painting (yay for 3 stage pearl) and the underside stripped and treated. I sold the car which allowed me to be in a much better place financially. Leading up to the sale I was already thinking about the replacement. In an ideal world it needed to be a good all-rounder. Something I can mess around with, modify, do track days, do the school run, go on long drives etc.  Options included but not limited to... Laurel C35, Evo 8/9, Civic FD2, Impreza Hawkeye, Aristo and even an Audi S4 Avant (I've already got the Mazda 6 wagon). But there was always one car at the top of the list The Toyota Mark ii JZX110 I found an advert on a Facebook group for an example in Japan, from a seller called Jon at Rising Sun Exports. A few messages back and forth and Jon calls me from Yokohama one morning (or afternoon in his case). He briefly explained the import process, the costs involved and a repeat of the advert. After much deliberation, the price was agreed and the sale was locked in. I've never imported a vehicle so I jumped into the unknown head first. The money transfer was completed through wise.com (fees apply), very easy to use and the money was with him within a day or two.  The car suspension was raised for the vessel and the car dropped off at the port. It was 7 weeks later when the bill of lading was received and the freight invoice sent to me, followed by the export certificate a couple of days after (both digital copies) In the mean time the port had been in contact. I needed an agent to deal with the NOVA (notification of vehicle arrival) along with the tax/duty invoice, this was £75.00. The port also had a fee of £100, I'm guessing to cover the cost of the 10 day 'free storage' and for moving the car off the boat etc. They need a copy of the vehicle invoice, freight invoice and export certificate to allow the vehicle to pass through customs. The vessel arrived on Tuesday 5th August, the tax/duty invoice was generated and sent over. This is generally tax 20% and duty 10% of the vehicle value. Although the invoice came in at a higher amount than I had calculated. Once HMRC had received the payment the vehicle could be released from customs. I thought once the tax/duty was paid you could collect at any point, that's not the case. Your agent will need to book a collection slot, I requested Thursday 7th which was accepted, with a 9:00am slot allocated. It was a 5:00am start from Norfolk heading to Southampton. We eventually found the compound, upon presenting the bill of lading and some ID they released the car (they drove it out of the compound to the front ready for us to load up). The email from the port stated each slot had a 10 minute window, which seemed abit farfetched but the staff said it's not a strict rule. We were there for approx. 30-40 mins in total. A week prior to collecting I contacted my garage and explained the situation, I was able to get an inspection slot that afternoon. For the registration, DVLA require the car to be insured, for this I used a company called Adrian Flux who can insure the vehicle using the VIN number.
    • Hey guys, looking for these side skirts if anyone can help me out.
    • Wife and I are still looking for a new home. One condition was a large enough garage for a full-size lift in one bay. Now if only we could find something... We've been looking for almost a year now.
    • Thanks everyone for the ideas! Sadly, ramps are a no go for me. With young kids at home, I do most of my work late at night while they're sleeping. Starting the car multiple times wouldn't be a great idea.  I'll go see one of those new long reach low profile jacks and take a couple measurements to see if they will fit.
