Hey guys and girls
Today i took my intake pipe off my car to replace my noisy BOV with the standard silent BOV, and as everyone does, i looked around to see if there was anything happening that shouldn't be.
I noticed there was some oil sitting on the bottom of the pipe and over the throttle butterfly!
Question?? What is happening?? i think it could be the gasket has gone on the turbo? or could it be sucking oil out of the engine via the vacumn line from over head the coil pack cover?
Cheers everyone who tries to help and has helped in the past.
i went to markets n bought a cheep shitty oil catch can, then found some old heater hose,
i cut where the blowby pipe thing goes to the intake and put a bolt in the hose, then put the heater hose on the rocker cover thing down to my catch can thats cable tied to my battery
think da pcv valve brings blowby gasses back to the intake manifold 2 b burned off completely. was learning bout it at TAFE last year but correct me if im wrong cuz i cant really remember. it doesnt affect the performance much but letting only fresh air into the intake manifold is always a good thingbut id check to see if its something else dats bringing oil into the intake pipe but most of the time its excessive blowby.
Edited by R33_NICK
wat is a pcv valve??
Positive Crankcase Ventilation
http://en.wikipedia.org/wiki/PCV_valve
Very good read
Something Holden engineers should have done a better job of with the old 308
Which is why they always seem to have oil leaks-even not long after new sump gaskets are installed
My god. English please?
    • LOL.... a good amount of people (not all) on that continent seem to know everything and like to measure things in bananas, football fields, statue of liberties instead of the metric system lol.
    • I assume the modules are similar enough, so if you've had no issues I don't see why I would. I have tried to find a wiring diagram for the FPCM / fuel pump circuit, but I can't find it anywhere. Otherwise, I would just do some wire cutting and joining at the FPCM and give the 12 V supplied to the FPCM directly to the pump instead. If you know anyone that could help with wiring diagrams, I'd be very happy
    • If it dies, then bypass. The task isn't difficult. I have one running on a standard R32 FPCM. That's after nearly 20 years of it running an 040, which pull substantially more current than the Walbro. They're not the same module, but I'd hope it indicates that the R33 one should be man enough for the job. I think people kill them when putting proper sized pumps on them, not these little toy pumps we're talking about here.
    • Silicone spray won't hurt anything. And if it does, that's an opportunity to put some solid steel spherical bushings in, so you can really learn what suspension noise sounds like, If you're going to try it, just spray one bush at a time, so you can work out which one is actually noisy. My best guess is that if the noise started only since putting the coilovers in, then it is just noise being transmitted up through the top mounts of the struts, and not necessarily "new" noise from bushes. But it's almost impossible to know.
    • Are you saying the 34 is SUV height, and not that we're talking about an SUV here? (because if we're talking about an SUV, you don't fix them. You just replace them when something breaks. Not worth establishing sufficient emotional connection with an SUV to warrant doing any work on one). I wouldn't jack my car up on a short little loop of 10mm steel rod poking out through a hole in the bumper bar, front or rear end. I realise that we're probably not talking about that type of loop at the front, being the one under/behind the bar on a Skyline.... but even for that one, trying to jack up on what amounts to a thin piece of steel, designed purely for withstanding a horizontal tension force, not a vertical compressive force (and so would be prone to buckling/crushing) and, my most particular bitch about it - located RIGHT AT THE EXTREME FRONT OF THE CAR, applying a load up through the radiator support panel, etc, with almost the entire mass of the car cantilevered between there and the rear wheels? Nope. Not doing that. Not on the regular. That structure out there in front of the front crossmember is not designed to carry load in the vertical direction. Not really designed to carry any load at all, really. The chassis rail that the tow point is connected to would be fine loaded in tension, as per towing. Not intended to carry the mass of the whole car, especially loaded all on one rail, with twisting and all sorts of shitty load distribution going on. No, I will happily drive up on some pieces of wood, thanks. That can only happen on driven wheels, and they are at the other end of the car, and this problem does not exist at that end of the car. And even then, I have been known to drive up on at least 1x piece of 2x8 each side at the rear, simply to reduce the amount of jack pumping necessary to get the car up high enough for the jack stands. What really really shits me about Skylines is the lack of decent places for chassis stands at either end of the car. You'd think they'd be designed into the crossmembers.
